[petsc-users] Modify RHS values at each iteration
Jed Brown
jedbrown at mcs.anl.gov
Thu Nov 21 00:09:46 CST 2013
TAY wee-beng <zonexo at gmail.com> writes:
> Hi,
> Due to a special case, I need modify RHS values of the system of eqns at
> each iteration.
> Hence, what I can do is to solve the eqn using KSPSolve, limit the
> maxits in KSPSetTolerances to 1, modify the RHS, and then run KSPSolve
> again.
> It will loop until it reaches the convergences I specify.
> My question is if that's the only way,
There is almost certainly a better way to formulate your problem.
> and will it suffer a large drop in speed?
That algorithm (without RHS modification) reduces to Richardson
preconditioned by one step of your chosen preconditioned iterative
method. This likely converges much worse than a Krylov method.
Note that in the form you describe, the preconditioner will be applied
twice and the operator once.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131120/2529bc57/attachment.pgp>
