[petsc-users] Modify RHS values at each iteration
TAY wee-beng zonexo at gmail.com
Thu Nov 21 00:04:24 CST 2013
Due to a special case, I need modify RHS values of the system of eqns at
each iteration.
Hence, what I can do is to solve the eqn using KSPSolve, limit the
maxits in KSPSetTolerances to 1, modify the RHS, and then run KSPSolve
again.
It will loop until it reaches the convergences I specify.
My question is if that's the only way, and will it suffer a large drop
in speed?
Thank you!
Yours sincerely,
TAY wee-beng
