[petsc-users] Understanding parallelism in DMPlexCreateBoxMesh
Jed Brown
jedbrown at mcs.anl.gov
Mon Nov 18 18:18:04 CST 2013
Geoffrey Irving <irving at naml.us> writes:
> DMPlexCreateSquareBoundary naively seems to
> 1. Create topology only on rank 0.
> 2. Set positions on all ranks.
> In particular, if seems to allocate space proportional to the entire
> number of vertices on every rank:
> ierr = PetscSectionGetStorageSize(coordSection, &coordSize);CHKERRQ(ierr);
> ierr = VecCreate(PetscObjectComm((PetscObject)dm),
> &coordinates);CHKERRQ(ierr);
> ierr = VecSetSizes(coordinates, coordSize, PETSC_DETERMINE);CHKERRQ(ierr);
> How does this code work? It's clearly intended to be callable in a
> parallel context given that it has a !rank conditional, and works as
> part of various examples, so I'm clearly missing something.
This just creates the mesh on rank 0. It is usually partitioned and
distributed subsequently (see src/snes/examples/tutorials/ex12.c). It's
fine for testing, but obviously non-scalable.
Now that Matt and I are running some larger tests with DMPlex, this is
one of the scalability issues that will be fixed.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131118/6361b65c/attachment.pgp>
