[petsc-users] Algorithms for counting nonzeros!
Wed Nov 13 13:40:16 CST 2013
On Wed, Nov 13, 2013 at 1:33 PM, Eric Chamberland <
Eric.Chamberland at giref.ulaval.ca> wrote:
> Hi all,
> we are in the process of adding new functionalities to our parallel
> finite-element code and are facing new challenges in computing the number
> of non-zeros of a sparse matrix.  Since we use Petsc, we want to be able to
> give this information before the first assembly (to pass to Mat{MPI,SEQ}
> AIJSetPreallocation).
> Willing to rewrite the nonzeros counting algorithm from scratch if
> necessary, we asked ourselves a number of questions:
> 1) Do algorithms in general count the *exact* number of non-zeros?  or do
> they just count a maximum and let Petsc release the memory after the first
> assembly?
> 2) How bad is it to reserve too-much non-zeros before the first assembly?
> 3) Where could we find some hints/articles examples or information about
> that kind of algorithm (working in parallel of course) ?
> Here is the context that we have up to now: we can manage a mixture of
> interpolations (P1, P2, discontinuous interpolations, etc) and of
> dimensions (scalar, 3D, etc) for all unknowns in a global matrix (example:
> a P2-P1 [Taylor-Hood] mixed formulation for Stokes problem).
> Since these parameters are determined at run-time (in fact they are user
> parameters), we have to think of a general algorithm to compute the
> "mostly" exact number of non-zeros for each matrix lines.
> Right now, we have a working, but memory consuming algorithm which
> computes the *exact* number on non-zeros per line (we exploded the memory
> for a problem with a little more than 2^31 unknowns with it -- using 64
> bits indices of course).  In fact, we manage to store the number of
> neighbors for each type of mesh components (ex: for a vertice, we have the
> following number of neighbors: vertices, edges, faces, and each type of
> elements).  It is costly and moreover will not handle the new
> functionalities we want in the code (XFEM for example).
DMPlex will do it already.
If you are opposed to using that, you can use Jed's simple method which is
to "fake" assemble without values,
putting all the (i,j) pairs into a hash table.
  Matt
> Thanks a lot!
> Eric
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131113/e568b5d8/attachment.html>
