[petsc-users] Algorithms for counting nonzeros!
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Wed Nov 13 13:33:42 CST 2013
Hi all,
we are in the process of adding new functionalities to our parallel
finite-element code and are facing new challenges in computing the
number of non-zeros of a sparse matrix. Since we use Petsc, we want to
be able to give this information before the first assembly (to pass to
Mat{MPI,SEQ}AIJSetPreallocation).
Willing to rewrite the nonzeros counting algorithm from scratch if
necessary, we asked ourselves a number of questions:
1) Do algorithms in general count the *exact* number of non-zeros? or
do they just count a maximum and let Petsc release the memory after the
first assembly?
2) How bad is it to reserve too-much non-zeros before the first assembly?
3) Where could we find some hints/articles examples or information about
that kind of algorithm (working in parallel of course) ?
Here is the context that we have up to now: we can manage a mixture of
interpolations (P1, P2, discontinuous interpolations, etc) and of
dimensions (scalar, 3D, etc) for all unknowns in a global matrix
(example: a P2-P1 [Taylor-Hood] mixed formulation for Stokes problem).
Since these parameters are determined at run-time (in fact they are user
parameters), we have to think of a general algorithm to compute the
"mostly" exact number of non-zeros for each matrix lines.
Right now, we have a working, but memory consuming algorithm which
computes the *exact* number on non-zeros per line (we exploded the
memory for a problem with a little more than 2^31 unknowns with it --
using 64 bits indices of course). In fact, we manage to store the
number of neighbors for each type of mesh components (ex: for a vertice,
we have the following number of neighbors: vertices, edges, faces, and
each type of elements). It is costly and moreover will not handle the
new functionalities we want in the code (XFEM for example).
Thanks a lot!
Eric
