[petsc-users] Debug AOCreateBasic
Tue Nov 5 23:22:56 CST 2013
Rongliang Chen <rongliang.chan at gmail.com> writes:
> Hi Jed,
> I tested my code on a locally 16-cores workstation. Both the MPICH and
> OPENMPI version work well for the  30 million unstructured meshes case
> (this workstation has 256G memory).
Then I would start thinking about an MPI problem and see if you can
configure to get a core dump.
> My code is also valgrind-clean on this workstation.
Good.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131105/c5df9029/attachment.pgp>
