[petsc-users] Solving Poisson equation with multigrid
Michele Rosso
mrosso at uci.edu
Fri May 31 17:44:35 CDT 2013
Thanks, but I'd rather use Cray since only a small part of my code
relies on PETSc and, as suggested by the BW staff,
Cray-compiled code performs generally better on Cray system.
Michele
On 05/31/2013 02:57 PM, Jed Brown wrote:
> Michele Rosso <mrosso at uci.edu> writes:
>> Hi,
>> I confirm that
>> -pc_type gamg -pc_mg_cycle_type v -pc_gamg_agg_nsmooths 1
>> produces the correct shift in PETSc 3.4.
>> So my problem is solved. I will upgrade to 3.4 in my productive
>> machine installation.
>> It is a Cray machine (Blue Waters). Assuming I want to use the Cray
>> compiler, which options should I use for ./configure
>> for the installation.
> Or the Intel compiler or GCC. PETSc should run at similar speed with
> any. IIRC, Cray recommends the Intel compiler on their machines with
> Intel CPUs. There are examples in config/examples/.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130531/16422331/attachment.html>
