[petsc-users] Solving Poisson equation with multigrid
Jed Brown
jedbrown at mcs.anl.gov
Fri May 24 17:22:46 CDT 2013
Matthew Knepley <knepley at gmail.com> writes:
> It looks like you are running in parallel (never do this until everything
> works in serial), which probably means you are using
> PCREDUNDANT for the coarse PC, so you need what Jed suggested:
> -mg_coarse_sub_pc_type svd
GAMG uses block Jacobi by default, not redundant. If it was redundant,
you would use -mg_coarse_redundant_pc_type svd.
