[petsc-users] Solving Poisson equation with multigrid
Fri May 24 16:51:29 CDT 2013
Michele Rosso <mrosso at uci.edu> writes:
>>     With petsc-3.4 (which you should upgrade to), use
>>     -mg_coarse_sub_pc_factor_shift_type NONZERO
Actually, use this with petsc-3.3 also (and please upgrade to
petsc-3.4).
The option you were passing was not being used.
