[petsc-users] 答复: 答复: 答复: 答复: 转发: PETsc problem
Mon May 20 10:23:18 CDT 2013
On Mon, 20 May 2013, 余浩 wrote:
> I can use cl to compile file under Windows. But even if I include path which cl is in in the enviromental variable of Cygwin, it still shows "Win32fe cl" does not work.
Have you checked the windows installation instructions?
https://www.mcs.anl.gov/petsc/documentation/installation.html#windows
You should start the 'compiler cmd' - and then run 'bash --login' inside it
[and not 'set cygwin path to include cl']
Satish
> The attached is the configure.log and make.log
> Thanks!
> Hao
> ________________________________
> 发件人: Matthew Knepley [knepley at gmail.com]
> 发送时间: 2013年5月11日 4:32
> 收件人: 余浩; petsc-users at mcs.anl.gov
> 主题: Re: 答复: [petsc-users] 答复: 答复: 转发: PETsc problem
> On Fri, May 10, 2013 at 12:11 PM, 余浩 <hao.yu at peraglobal.com<mailto:hao.yu at peraglobal.com>> wrote:
> What do you mean by compiling something with it ? I don't know. you mean 'win32fe cl' is not installed correctly?
> I mean, can you compile a file using cl from the command line?
>    Matt
> Hao
> 发件人: Matthew Knepley [knepley at gmail.com<mailto:knepley at gmail.com>]
> 发送时间: 2013年5月10日 19:55
> 收件人: 余浩
> 抄送: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
> 主题: Re: [petsc-users] 答复: 答复: 转发: PETsc problem
> On Fri, May 10, 2013 at 6:20 AM, 余浩 <hao.yu at peraglobal.com<mailto:hao.yu at peraglobal.com>> wrote:
> The configure.log and make.log are attached.
> it shows that 'win32fe cl' does not work.  I dont' know what the problem is.
> Can you compile something with it? It looks like it is not installed correctly.
>    Matt
> Thanks!
> Hao
> 发件人: Jed Brown [five9a2 at gmail.com<mailto:five9a2 at gmail.com>] 代表 Jed Brown [jedbrown at mcs.anl.gov<mailto:jedbrown at mcs.anl.gov>]
> 发送时间: 2013年5月10日 15:16
> 主题: Re: [petsc-users] 答复:  转发: PETsc problem
> 余浩 <hao.yu at peraglobal.com<mailto:hao.yu at peraglobal.com>> writes:
> You couldn't have found a less helpful way to report this.
> Note the bold part:
> http://www.mcs.anl.gov/petsc/documentation/bugreporting.html
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> -- Norbert Wiener
