[petsc-users] 答复: 答复: 答复: 答复: 转发: PETsc problem
余浩 hao.yu at peraglobal.com
Mon May 20 04:08:05 CDT 2013
I can use cl to compile file under Windows. But even if I include path which cl is in in the enviromental variable of Cygwin, it still shows "Win32fe cl" does not work. The attached is the configure.log and make.log
Thanks!
Hao
发件人: Matthew Knepley [knepley at gmail.com]
发送时间: 2013年5月11日 4:32
收件人: 余浩; petsc-users at mcs.anl.gov
主题: Re: 答复: [petsc-users] 答复: 答复: 转发: PETsc problem
On Fri, May 10, 2013 at 12:11 PM, 余浩 <hao.yu at peraglobal.com<mailto:hao.yu at peraglobal.com>> wrote:
What do you mean by compiling something with it ? I don't know. you mean 'win32fe cl' is not installed correctly?
I mean, can you compile a file using cl from the command line?
   Matt
Hao
发件人: Matthew Knepley [knepley at gmail.com<mailto:knepley at gmail.com>]
发送时间: 2013年5月10日 19:55
收件人: 余浩
抄送: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
主题: Re: [petsc-users] 答复: 答复: 转发: PETsc problem
On Fri, May 10, 2013 at 6:20 AM, 余浩 <hao.yu at peraglobal.com<mailto:hao.yu at peraglobal.com>> wrote:
The configure.log and make.log are attached.
it shows that 'win32fe cl' does not work.  I dont' know what the problem is.
Can you compile something with it? It looks like it is not installed correctly.
   Matt
Thanks!
Hao
发件人: Jed Brown [five9a2 at gmail.com<mailto:five9a2 at gmail.com>] 代表 Jed Brown [jedbrown at mcs.anl.gov<mailto:jedbrown at mcs.anl.gov>]
发送时间: 2013年5月10日 15:16
主题: Re: [petsc-users] 答复:  转发: PETsc problem
余浩 <hao.yu at peraglobal.com<mailto:hao.yu at peraglobal.com>> writes:
You couldn't have found a less helpful way to report this.
Note the bold part:
http://www.mcs.anl.gov/petsc/documentation/bugreporting.html
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130520/ed400f45/attachment-0001.html>
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130520/ed400f45/attachment-0002.obj>
Desc: make.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130520/ed400f45/attachment-0003.obj>
