[petsc-users] Solving Poisson equation with multigrid
Jed Brown
jedbrown at mcs.anl.gov
Fri May 17 19:10:35 CDT 2013
Please always use "reply-all" so that your messages go to the list.
This is standard mailing list etiquette. It is important to preserve
threading for people who find this discussion later and so that we do
not waste our time re-answering the same questions that have already
been answered in private side-conversations. You'll likely get an
answer faster that way too.
Michele Rosso <mrosso at uci.edu> writes:
> If you are referring to -pc_type gamg, I tried it, but I got the same
> error message
> (For coloring efficiency ensure number of grid points in X is divisible
> by 2*stencil_width + 1)
The option could not have been used. Always send the ENTIRE error
message. Is the code calling KSPSetFromOptions()? Run with
-options_left to see if any options did not get used.
> On 05/17/2013 04:49 PM, Jed Brown wrote:
>> Read my first message
>> On May 17, 2013 6:47 PM, "Michele Rosso" <mrosso at uci.edu
>> <mailto:mrosso at uci.edu>> wrote:
>> Ok, I will give a try to AMG then. What is it exactly?
>> Thank you!
>> On 05/17/2013 04:25 PM, Jed Brown wrote:
>>> Michele Rosso<mrosso at uci.edu> <mailto:mrosso at uci.edu> writes:
>>>> So should I always use an odd number of grid points?
>>>> There is no way around this?
>>> If you want to use regular geometric coarsening, then yes. That *is*
>>> regular node-centered coarsening. Just consider the base case of one
>>> element:
>>> o ------- o
>>> Split that in two:
>>> o -- o -- o
>>> Look, an odd number of vertices, and as we keep refining, it will stay
>>> odd.
>>> You can use AMG or write your own interpolation if you want irregular coarsening.
