[petsc-users] Solving Poisson equation with multigrid
Jed Brown
jedbrown at mcs.anl.gov
Fri May 17 18:25:57 CDT 2013
Michele Rosso <mrosso at uci.edu> writes:
> So should I always use an odd number of grid points?
> There is no way around this?
If you want to use regular geometric coarsening, then yes. That *is*
regular node-centered coarsening. Just consider the base case of one
element:
o ------- o
Split that in two:
o -- o -- o
Look, an odd number of vertices, and as we keep refining, it will stay
odd.
You can use AMG or write your own interpolation if you want irregular coarsening.
