[petsc-users] slepc build fails..
Dharmendar Reddy dharmareddy84 at gmail.com
Sun May 5 02:30:03 CDT 2013
On Sun, May 5, 2013 at 1:06 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Dharmendar Reddy <dharmareddy84 at gmail.com> writes:
> > Hello,
> >          I am getting an error when i try to build slepc.
> > I first see:
> >       CMake setup incomplete (status 256), falling back to legacy
> > build
> This problem, which is definitely a CMake bug (but they seem to have no
> plans to fix), is usually related to NOTFOUND cache entries:
>   //Path to a library.
>   -LARPACKLIB:FILEPATH=-LARPACKLIB-NOTFOUND
> This is probably constructed by joining an empty variable.  Jose may
> know where in the SLEPc CMake code to look for this occurring.
> > then make all gives an error, look at the attached logs
> Does 'make test' work?  What about after 'make allfortranstubs all'?
   Make test works.
  login4$ make SLEPC_DIR=$PWD
PETSC_DIR=/home1/00924/Reddy135/LocalApps/petsc PETSC_ARCH=mp
i_rScalar_Opt test
Running test examples to verify correct installation
Using SLEPC_DIR=/home1/00924/Reddy135/LocalApps/slepc,
alApps/petsc and PETSC_ARCH=mpi_rScalar_Opt
C/C++ example src/eps/examples/tests/test10 run successfully with 1 MPI
process
C/C++ example src/eps/examples/tests/test10 run successfully with 2 MPI
process
Fortran example src/eps/examples/tests/test7f run successfully with 1 MPI
process
Completed test examples
 But
 fails..
grep: ftn-auto/makefile: No such file or directory
libfast in: /home1/00924/Reddy135/LocalApps/slepc/include/finclude/ftn-auto
make[5]: *** No rule to make target `slepc_tree'.  Stop.
libfast in:
/home1/00924/Reddy135/LocalApps/slepc/include/finclude/ftn-custom
libfast in: /home1/00924/Reddy135/LocalApps/slepc/include/slepc-private
libfast in: /home1/00924/Reddy135/LocalApps/slepc/docs
Completed building libraries
making shared libraries in
/home1/00924/Reddy135/LocalApps/slepc/mpi_rScalar_Opt/lib
building libslepc.so
*******************************ERROR************************************
  Error during compile, check mpi_rScalar_Opt/conf/make.log
  Send all contents of mpi_rScalar_Opt/conf to slepc-maint at grycap.upv.es
Now, i am wondering why i get these errors now ? i had no issues with slepc
until i did git pull on petsc today. petsc does compile and pass tests. ?
I am using slepc-dev -rev 3324
Thanks
Reddy
Dharmendar Reddy Palle
Graduate Student
Microelectronics Research center,
University of Texas at Austin,
10100 Burnet Road, Bldg. 160
MER 2.608F, TX 78758-4445
e-mail: dharmareddy84 at gmail.com
Phone: +1-512-350-9082
United States of America.
Homepage: https://webspace.utexas.edu/~dpr342
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130505/dff5383e/attachment.html>
