[petsc-users] dense matrix problem
Thu Jan 31 10:09:48 CST 2013
On Thu, Jan 31, 2013 at 11:07 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> "result is incorrect" is not helpful. Please include diagnostics. Are you
> using an iterative or direct solver? Start here if you don't know what to
> check:
> http://scicomp.stackexchange.com/questions/513/why-is-my-iterative-linear-solver-not-converging
And ASM works great for these problems:
   http://arxiv.org/abs/0909.5413
       Matt
> On Thu, Jan 31, 2013 at 9:58 AM, Alex Salazar <alejandrocof at gmail.com>wrote:
>> Hello, everyone
>> I want to get the solution of algrebraic system (with a  dense
>> zero-diagonal simetric matrix) of a interpolation problem (using radial
>> basis functions) with Petsc.
>>  For a few points (around 10 elements) using KSP I get the correct
>> solution,  however when  I increase the number of points,  the result is
>> incorrect.
>> Any Idea ?
>> Regards Alejandro.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130131/ccbac111/attachment.html>
