[petsc-users] dense matrix problem
Thu Jan 31 10:07:49 CST 2013
"result is incorrect" is not helpful. Please include diagnostics. Are you
using an iterative or direct solver? Start here if you don't know what to
check:
http://scicomp.stackexchange.com/questions/513/why-is-my-iterative-linear-solver-not-converging
On Thu, Jan 31, 2013 at 9:58 AM, Alex Salazar <alejandrocof at gmail.com>wrote:
> Hello, everyone
> I want to get the solution of algrebraic system (with a  dense
> zero-diagonal simetric matrix) of a interpolation problem (using radial
> basis functions) with Petsc.
>  For a few points (around 10 elements) using KSP I get the correct
> solution,  however when  I increase the number of points,  the result is
> incorrect.
> Any Idea ?
> Regards Alejandro.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130131/5548bcf3/attachment.html>
