[petsc-users] Reading a rectangular system from a file on disk and solving system in parallel
Jed Brown
jedbrown at mcs.anl.gov
Wed Jan 23 07:00:44 CST 2013
On Wed, Jan 23, 2013 at 12:28 AM, Gaurish Telang <gaurish108 at gmail.com>wrote:
> Hi
> I want to solve a least squares problem min || Ax - b|| in parallel with
> PETSc.
> I have the matrix A and the column vector b stored in files which are in
> PETSc' s binary format.
> So far, I am able to read both these files and solve the least squares
> system with PETSc's lsqr routine on a single processor.
> To solve the least squares system in parallel, can someone guide me on how
> to distribute the matrix A and vector b among several processors after
> reading A and b from the corresponding files on disk?
Did you try just not VecSetType and MatSetType to force SEQ
implementations? It's better to call MatSetFromOptions() and
VecSetFromOptions() so you can change the type at run-time.
src/ksp/ksp/examples/tutorials/ex10.c automatically loads the matrix in
parallel and solves non-square systems (use -ksp_type lsqr).
> For reference, I have pasted my code below, which works well on a single
> processor.
> Thank you,
> Gaurish
> static char help[] = "--";
> #include <petscksp.h>
> #include <petscsys.h>
> #include <stdio.h>
> #undef __FUNCT__
> #define __FUNCT__ "main"
> int main(int argc,char **args)
> Vec x, b, residue; /* approx solution, RHS, residual */
> Mat A; /* linear system matrix */
> KSP ksp; /* linear solver context */
> PC pc; /* preconditioner context */
> PetscErrorCode ierr;
> PetscInt m,n ; /* # number of rows and columns of the
> matrix read in*/
> PetscViewer fd ;
> PetscInt size, its;
> PetscScalar norm, tol=1.e-5;
> PetscBool flg;
> char fmat[PETSC_MAX_PATH_LEN]; /* input file names */
> char frhs[PETSC_MAX_PATH_LEN]; /* input file names */
> PetscInitialize(&argc,&args,(char *)0,help);
> ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr);
> if (size != 1) SETERRQ(PETSC_COMM_WORLD,1,"This is a uniprocessor
> example only!");
> ierr =
> PetscOptionsGetString(PETSC_NULL,"-fmat",fmat,PETSC_MAX_PATH_LEN,&flg);
> ierr =
> PetscOptionsGetString(PETSC_NULL,"-frhs",frhs,PETSC_MAX_PATH_LEN,&flg);
> /* Read in the matrix */
> ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD, fmat, FILE_MODE_READ, &fd
> ); CHKERRQ(ierr);
> ierr = MatCreate(PETSC_COMM_WORLD,&A);
> ierr = MatSetType(A,MATSEQAIJ);
> ierr = MatLoad(A,fd);
> ierr = PetscViewerDestroy(&fd);
> /*Read in the right hand side*/
> ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD, frhs, FILE_MODE_READ, &fd
> ); CHKERRQ(ierr);
> ierr = VecCreate(PETSC_COMM_WORLD,&b);
> ierr = VecSetType(b,VECSEQ);
> ierr = VecLoad(b,fd);
> /* Get the matrix size. Used for setting the vector sizes*/
> ierr = MatGetSize(A , &m, &n);
> printf("The size of the matrix read in is %d x %d\n", m , n);
> ierr = VecCreateSeq(PETSC_COMM_WORLD,n, &x);
> ierr = VecCreateSeq(PETSC_COMM_WORLD,m, &residue);
> /* Set the solver type at the command-line */
> ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
> ierr = KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);CHKERRQ(ierr);
> ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
> ierr = PCSetType(pc,PCNONE);CHKERRQ(ierr);
> ierr =
> KSPSetTolerances(ksp,1.e-5,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);CHKERRQ(ierr);
> /* Set runtime options, e.g.,
> -ksp_type <type> -pc_type <type> -ksp_monitor -ksp_rtol <rtol>
> These options will override those specified above as long as
> KSPSetFromOptions() is called _after_ any other customization
> routines */
> ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
> /* Initial guess for the krylov method set to zero*/
> PetscScalar p = 0;
> ierr = VecSet(x,p);CHKERRQ(ierr);
> ierr = KSPSetInitialGuessNonzero(ksp,PETSC_TRUE);CHKERRQ(ierr);
> /* Solve linear system */
> ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
> /* View solver info; we could instead use the option -ksp_view to print
> this info to the screen at the conclusion of KSPSolve().*/
> ierr = KSPView(ksp,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
> /*View the numerical solution and the residue vector*/
> printf("-------------------\nThe numerical solution is x = \n");
> ierr = VecView(x,PETSC_VIEWER_STDOUT_SELF);
> printf("-------------------\nThe residue vector Ax - b is = \n");
> ierr = MatMult(A,x,residue);CHKERRQ(ierr);
> ierr = VecAXPY(residue,-1.0,b);CHKERRQ(ierr);
> ierr = VecView(residue,PETSC_VIEWER_STDOUT_SELF);
> /* Clean up */
> ierr = VecDestroy(&x);CHKERRQ(ierr);
> ierr = VecDestroy(&residue);CHKERRQ(ierr);
> ierr = VecDestroy(&b);CHKERRQ(ierr);
> ierr = MatDestroy(&A);CHKERRQ(ierr);
> ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
> ierr = PetscFinalize();
> return 0;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130123/0e63795e/attachment.html>
