[petsc-users] Reading a rectangular system from a file on disk and solving system in parallel
Gaurish Telang
gaurish108 at gmail.com
Wed Jan 23 00:28:26 CST 2013
Hi
I want to solve a least squares problem min || Ax - b|| in parallel with
PETSc.
I have the matrix A and the column vector b stored in files which are in
PETSc' s binary format.
So far, I am able to read both these files and solve the least squares
system with PETSc's lsqr routine on a single processor.
To solve the least squares system in parallel, can someone guide me on how
to distribute the matrix A and vector b among several processors after
reading A and b from the corresponding files on disk?
For reference, I have pasted my code below, which works well on a single
processor.
Thank you,
Gaurish
static char help[] = "--";
#include <petscksp.h>
#include <petscsys.h>
#include <stdio.h>
#undef __FUNCT__
#define __FUNCT__ "main"
int main(int argc,char **args)
Vec x, b, residue; /* approx solution, RHS, residual */
Mat A; /* linear system matrix */
KSP ksp; /* linear solver context */
PC pc; /* preconditioner context */
PetscErrorCode ierr;
PetscInt m,n ; /* # number of rows and columns of the matrix
read in*/
PetscViewer fd ;
PetscInt size, its;
PetscScalar norm, tol=1.e-5;
PetscBool flg;
char fmat[PETSC_MAX_PATH_LEN]; /* input file names */
char frhs[PETSC_MAX_PATH_LEN]; /* input file names */
PetscInitialize(&argc,&args,(char *)0,help);
ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr);
if (size != 1) SETERRQ(PETSC_COMM_WORLD,1,"This is a uniprocessor example
only!");
ierr =
PetscOptionsGetString(PETSC_NULL,"-fmat",fmat,PETSC_MAX_PATH_LEN,&flg);
ierr =
PetscOptionsGetString(PETSC_NULL,"-frhs",frhs,PETSC_MAX_PATH_LEN,&flg);
/* Read in the matrix */
ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD, fmat, FILE_MODE_READ, &fd
); CHKERRQ(ierr);
ierr = MatCreate(PETSC_COMM_WORLD,&A);
ierr = MatSetType(A,MATSEQAIJ);
ierr = MatLoad(A,fd);
ierr = PetscViewerDestroy(&fd);
/*Read in the right hand side*/
ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD, frhs, FILE_MODE_READ, &fd
); CHKERRQ(ierr);
ierr = VecCreate(PETSC_COMM_WORLD,&b);
ierr = VecSetType(b,VECSEQ);
ierr = VecLoad(b,fd);
/* Get the matrix size. Used for setting the vector sizes*/
ierr = MatGetSize(A , &m, &n);
printf("The size of the matrix read in is %d x %d\n", m , n);
ierr = VecCreateSeq(PETSC_COMM_WORLD,n, &x);
ierr = VecCreateSeq(PETSC_COMM_WORLD,m, &residue);
/* Set the solver type at the command-line */
ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
ierr = KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);CHKERRQ(ierr);
ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
ierr = PCSetType(pc,PCNONE);CHKERRQ(ierr);
ierr =
KSPSetTolerances(ksp,1.e-5,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);CHKERRQ(ierr);
/* Set runtime options, e.g.,
-ksp_type <type> -pc_type <type> -ksp_monitor -ksp_rtol <rtol>
These options will override those specified above as long as
KSPSetFromOptions() is called _after_ any other customization
routines */
ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
/* Initial guess for the krylov method set to zero*/
PetscScalar p = 0;
ierr = VecSet(x,p);CHKERRQ(ierr);
ierr = KSPSetInitialGuessNonzero(ksp,PETSC_TRUE);CHKERRQ(ierr);
/* Solve linear system */
ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
/* View solver info; we could instead use the option -ksp_view to print
this info to the screen at the conclusion of KSPSolve().*/
ierr = KSPView(ksp,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
/*View the numerical solution and the residue vector*/
printf("-------------------\nThe numerical solution is x = \n");
ierr = VecView(x,PETSC_VIEWER_STDOUT_SELF);
printf("-------------------\nThe residue vector Ax - b is = \n");
ierr = MatMult(A,x,residue);CHKERRQ(ierr);
ierr = VecAXPY(residue,-1.0,b);CHKERRQ(ierr);
ierr = VecView(residue,PETSC_VIEWER_STDOUT_SELF);
/* Clean up */
ierr = VecDestroy(&x);CHKERRQ(ierr);
ierr = VecDestroy(&residue);CHKERRQ(ierr);
ierr = VecDestroy(&b);CHKERRQ(ierr);
ierr = MatDestroy(&A);CHKERRQ(ierr);
ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
ierr = PetscFinalize();
return 0;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130123/9b1f1371/attachment.html>
