[petsc-users] PETSc 3.3 p5 installation newbie question
Zou (Non-US), Ling
ling.zou at inl.gov
Mon Jan 21 19:06:54 CST 2013
Jed, thanks again for your reply. Have a good night.
Ling
On Mon, Jan 21, 2013 at 6:05 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Mon, Jan 21, 2013 at 7:03 PM, Zou (Non-US), Ling <ling.zou at inl.gov>wrote:
>> Thank you Jed.
>> After 'export PETSC_DIR=/opt/packages/petsc/petsc-3.3-p5
>> PETSC_ARCH=arch-darwin-c-debug',
>> 'make alltests' seems working well. This is what I got, not a big
>> difference, should it be a concern?
> It's fine, the default tolerances are just a hair too tight. (Hopefully
> we'll move to a better testing system so these false positives go away.)
>> tee: arch-darwin-c-debug/conf/alltests.log: No such file or directory
>> 4c4
>> < 3 SNES Function norm 5.48028e-09
>> > 3 SNES Function norm 5.48039e-09
>> /opt/packages/petsc/petsc-3.3-p5/src/snes/examples/tests
>> Possible problem with with ex1_3, diffs above
>> 5c5
>> < 2 SNES Function norm 0.000452855
>> > 2 SNES Function norm 0.000452848
>> 7c7
>> < 3 SNES Function norm 1.39154e-09
>> > 3 SNES Function norm 1.39443e-09
>> Possible problem with with ex7_1, diffs above
>> 5c5
>> 7c7
>> Possible problem with with ex7_2, diffs above
>> 4c4
>> < 3 SNES Function norm 2.083e-10
>> > 3 SNES Function norm 2.081e-10
>> Possible problem with with ex9_1, diffs above
>> make: [alltests] Error 1 (ignored)
>> Best,
>> Ling
>> On Mon, Jan 21, 2013 at 5:55 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> I think you're looking for
>>> (or include in make command) followed by
>>> make ex1
>>> make runex1
>>> You can also
>>> make alltests
>>> but this is overkill.
>>> On Mon, Jan 21, 2013 at 6:41 PM, Zou (Non-US), Ling <ling.zou at inl.gov>wrote:
>>>> Hi, all
>>>> I downloaded the PETSc 3.3 p5 version and installed it. Everything
>>>> seems to be working fine as I followed those instructions and eventually I
>>>> did the test like:
>>>> make PETSC_DIR=/opt/packages/petsc/petsc-3.3-p5
>>>> PETSC_ARCH=arch-darwin-c-debug test
>>>> and I got:
>>>> Running test examples to verify correct installation
>>>> Using PETSC_DIR=/opt/packages/petsc/petsc-3.3-p5 and
>>>> C/C++ example src/snes/examples/tutorials/ex19 run *successfully* with
>>>> 1 MPI process
>>>> 2 MPI processes
>>>> Fortran example src/snes/examples/tutorials/ex5f run *successfully*with 1 MPI process
>>>> Completed test examples
>>>> I guess everything so far is good.
>>>> Question:
>>>> When I went to petsc-3.3-p5/src/snes/examples/tests, trying to see how
>>>> those example codes work, I did these and none of them worked.
>>>> ../petsc-3.3-p5/src/snes/examples/tests]> make
>>>> makefile:12: /conf/variables: No such file or directory
>>>> makefile:13: /conf/rules: No such file or directory
>>>> makefile:259: /conf/test: No such file or directory
>>>> make: *** No rule to make target `/conf/test'. Stop.
>>>> ../petsc-3.3-p5/src/snes/examples/tests]> make test
>>>> PETSC_DIR=/opt/packages/petsc/petsc-3.3-p5 PETSC_ARCH=arch-darwin-c-debug
>>>> (nothing happened, or at least nothing showed)
>>>> test
>>>> make: *** No rule to make target `test'. Stop.
>>>> I'd greatly appreciate it if anybody could give me a hand on this.
>>>> Best,
>>>> Ling
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130121/63b36a95/attachment.html>
