[petsc-users] PETSc 3.3 p5 installation newbie question
Mon Jan 21 19:05:19 CST 2013
On Mon, Jan 21, 2013 at 7:03 PM, Zou (Non-US), Ling <ling.zou at inl.gov>wrote:
> Thank you Jed.
> After 'export PETSC_DIR=/opt/packages/petsc/petsc-3.3-p5
> PETSC_ARCH=arch-darwin-c-debug',
> 'make alltests' seems working well. This is what I got, not a big
> difference, should it be a concern?
It's fine, the default tolerances are just a hair too tight. (Hopefully
we'll move to a better testing system so these false positives go away.)
> tee: arch-darwin-c-debug/conf/alltests.log: No such file or directory
> 4c4
> <   3 SNES Function norm 5.48028e-09
> >   3 SNES Function norm 5.48039e-09
> /opt/packages/petsc/petsc-3.3-p5/src/snes/examples/tests
> Possible problem with with ex1_3, diffs above
> 5c5
> <   2 SNES Function norm 0.000452855
> >   2 SNES Function norm 0.000452848
> 7c7
> <   3 SNES Function norm 1.39154e-09
> >   3 SNES Function norm 1.39443e-09
> Possible problem with with ex7_1, diffs above
> 5c5
> 7c7
> Possible problem with with ex7_2, diffs above
> 4c4
> <   3 SNES Function norm 2.083e-10
> >   3 SNES Function norm 2.081e-10
> Possible problem with with ex9_1, diffs above
> make: [alltests] Error 1 (ignored)
> Best,
> Ling
> On Mon, Jan 21, 2013 at 5:55 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> I think you're looking for
>> (or include in make command) followed by
>> make ex1
>> make runex1
>> You can also
>> make alltests
>> but this is overkill.
>> On Mon, Jan 21, 2013 at 6:41 PM, Zou (Non-US), Ling <ling.zou at inl.gov>wrote:
>>> Hi, all
>>> I downloaded the PETSc 3.3 p5 version and installed it. Everything seems
>>> to be working fine as I followed those instructions and eventually I did
>>> the test like:
>>> make PETSC_DIR=/opt/packages/petsc/petsc-3.3-p5
>>> PETSC_ARCH=arch-darwin-c-debug test
>>> and I got:
>>> Running test examples to verify correct installation
>>> Using PETSC_DIR=/opt/packages/petsc/petsc-3.3-p5 and
>>> C/C++ example src/snes/examples/tutorials/ex19 run *successfully* with
>>> 1 MPI process
>>> 2 MPI processes
>>> Fortran example src/snes/examples/tutorials/ex5f run *successfully*with 1 MPI process
>>> Completed test examples
>>> I guess everything so far is good.
>>> Question:
>>> When I went to petsc-3.3-p5/src/snes/examples/tests, trying to see how
>>> those example codes work, I did these and none of them worked.
>>> ../petsc-3.3-p5/src/snes/examples/tests]> make
>>> makefile:12: /conf/variables: No such file or directory
>>> makefile:13: /conf/rules: No such file or directory
>>> makefile:259: /conf/test: No such file or directory
>>> make: *** No rule to make target `/conf/test'.  Stop.
>>> ../petsc-3.3-p5/src/snes/examples/tests]> make test
>>> PETSC_DIR=/opt/packages/petsc/petsc-3.3-p5 PETSC_ARCH=arch-darwin-c-debug
>>> (nothing happened, or at least nothing showed)
>>> test
>>> make: *** No rule to make target `test'.  Stop.
>>> I'd greatly appreciate it if anybody could give me a hand on this.
>>> Best,
>>> Ling
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130121/716c31df/attachment-0001.html>
