[petsc-users] PETSc 3.3 p5 installation newbie question
Jed Brown
jedbrown at mcs.anl.gov
Mon Jan 21 18:55:48 CST 2013
I think you're looking for
export PETSC_DIR=/opt/packages/petsc/petsc-3.3-p5
PETSC_ARCH=arch-darwin-c-debug
(or include in make command) followed by
make ex1
make runex1
You can also
make alltests
but this is overkill.
On Mon, Jan 21, 2013 at 6:41 PM, Zou (Non-US), Ling <ling.zou at inl.gov>wrote:
> Hi, all
> I downloaded the PETSc 3.3 p5 version and installed it. Everything seems
> to be working fine as I followed those instructions and eventually I did
> the test like:
> make PETSC_DIR=/opt/packages/petsc/petsc-3.3-p5
> PETSC_ARCH=arch-darwin-c-debug test
> and I got:
> Running test examples to verify correct installation
> Using PETSC_DIR=/opt/packages/petsc/petsc-3.3-p5 and
> C/C++ example src/snes/examples/tutorials/ex19 run *successfully* with 1
> MPI process
> C/C++ example src/snes/examples/tutorials/ex19 run *successfully* with 2
> MPI processes
> Fortran example src/snes/examples/tutorials/ex5f run *successfully* with
> 1 MPI process
> Completed test examples
> I guess everything so far is good.
> Question:
> When I went to petsc-3.3-p5/src/snes/examples/tests, trying to see how
> those example codes work, I did these and none of them worked.
> ../petsc-3.3-p5/src/snes/examples/tests]> make
> makefile:12: /conf/variables: No such file or directory
> makefile:13: /conf/rules: No such file or directory
> makefile:259: /conf/test: No such file or directory
> make: *** No rule to make target `/conf/test'. Stop.
> ../petsc-3.3-p5/src/snes/examples/tests]> make test
> PETSC_DIR=/opt/packages/petsc/petsc-3.3-p5 PETSC_ARCH=arch-darwin-c-debug
> (nothing happened, or at least nothing showed)
> test
> make: *** No rule to make target `test'. Stop.
> I'd greatly appreciate it if anybody could give me a hand on this.
> Best,
> Ling
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130121/4e7518fc/attachment.html>
