[petsc-users] PETSc 3.3 p5 installation newbie question
Zou (Non-US), Ling
ling.zou at inl.gov
Mon Jan 21 18:41:31 CST 2013
Hi, all
I downloaded the PETSc 3.3 p5 version and installed it. Everything seems to
be working fine as I followed those instructions and eventually I did the
test like:
make PETSC_DIR=/opt/packages/petsc/petsc-3.3-p5
PETSC_ARCH=arch-darwin-c-debug test
and I got:
Running test examples to verify correct installation
Using PETSC_DIR=/opt/packages/petsc/petsc-3.3-p5 and
C/C++ example src/snes/examples/tutorials/ex19 run *successfully* with 1
MPI process
C/C++ example src/snes/examples/tutorials/ex19 run *successfully* with 2
MPI processes
Fortran example src/snes/examples/tutorials/ex5f run *successfully* with 1
MPI process
Completed test examples
I guess everything so far is good.
Question:
When I went to petsc-3.3-p5/src/snes/examples/tests, trying to see how
those example codes work, I did these and none of them worked.
../petsc-3.3-p5/src/snes/examples/tests]> make
makefile:12: /conf/variables: No such file or directory
makefile:13: /conf/rules: No such file or directory
makefile:259: /conf/test: No such file or directory
make: *** No rule to make target `/conf/test'. Stop.
../petsc-3.3-p5/src/snes/examples/tests]> make test
PETSC_DIR=/opt/packages/petsc/petsc-3.3-p5 PETSC_ARCH=arch-darwin-c-debug
(nothing happened, or at least nothing showed)
test
make: *** No rule to make target `test'. Stop.
I'd greatly appreciate it if anybody could give me a hand on this.
Best,
Ling
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130121/98072041/attachment.html>
