[petsc-users] MatMatMult size error
Jim Fonseca jefonseca at gmail.com
Wed Jan 16 22:47:05 CST 2013
Dear Jose,
Thanks for looking into this.  I seem to still be getting a error with the
new change in revision 3170: (I was trying 3169 previously).
/home/jfonseca/NEMOdevcarter/libs/slepc/build-real/include/slepcst.h(116):
error: identifier "PetscFunctionList" is undefined
  PETSC_EXTERN PetscFunctionList STList;
Jim
On Wed, Jan 16, 2013 at 2:18 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 16/01/2013, a las 19:59, Jim Fonseca escribió:
> > Hi,
> > Thanks for the suggestion about PETSc-dev regarding the MatMatMult issue.
> > I was able to build PETSc-dev, but slepc-dev gives me errors I haven't
> seen before. Logs are attached. Any ideas?
> > BEGINNING TO COMPILE LIBRARIES IN ALL DIRECTORIES
> > libfast in: /home/jfonseca/NEMOdevcarter/libs/slepc/build-real/src
> > libfast in: /home/jfonseca/NEMOdevcarter/libs/slepc/build-real/src/eps
> > libfast in:
> /home/jfonseca/NEMOdevcarter/libs/slepc/build-real/src/eps/interface
> > basic.c(560): error: argument of type "PetscFList" is incompatible with
> parameter of type "MPI_Comm={int}"
> >     ierr =
> PetscFListFind(EPSList,((PetscObject)eps)->comm,type,PETSC_TRUE,(void
> (**)(void)) &r);CHKERRQ(ierr);
> > Thanks,
> > Jim
> I know slepc-dev is broken but haven't had time to fix. Try updating in a
> few hours.
> Jose
Jim Fonseca, PhD
Research Scientist
Network for Computational Nanotechnology
Purdue University
765-496-6495
www.jimfonseca.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130116/b7e68dbf/attachment.html>
