[petsc-users] MatMatMult size error
Jose E. Roman
jroman at dsic.upv.es
Wed Jan 16 13:18:31 CST 2013
El 16/01/2013, a las 19:59, Jim Fonseca escribió:
> Hi,
> Thanks for the suggestion about PETSc-dev regarding the MatMatMult issue.
> I was able to build PETSc-dev, but slepc-dev gives me errors I haven't seen before. Logs are attached. Any ideas?
> BEGINNING TO COMPILE LIBRARIES IN ALL DIRECTORIES
> libfast in: /home/jfonseca/NEMOdevcarter/libs/slepc/build-real/src
> libfast in: /home/jfonseca/NEMOdevcarter/libs/slepc/build-real/src/eps
> libfast in: /home/jfonseca/NEMOdevcarter/libs/slepc/build-real/src/eps/interface
> basic.c(560): error: argument of type "PetscFList" is incompatible with parameter of type "MPI_Comm={int}"
> ierr = PetscFListFind(EPSList,((PetscObject)eps)->comm,type,PETSC_TRUE,(void (**)(void)) &r);CHKERRQ(ierr);
> Thanks,
> Jim
I know slepc-dev is broken but haven't had time to fix. Try updating in a few hours.
Jose
