[petsc-users] Petsc 3.3.p5 with HYPRE 2.9.0b
Jed Brown
jedbrown at mcs.anl.gov
Wed Jan 9 06:40:39 CST 2013
Petsc-3.3 was released half a year before hypre-2.9. The hypre developers
say they noticed the bug shortly after publishing the tarball, but did not
make a patch release. You can either (a) talk them into giving you/us the
patch or (b) publishing a patch release with a fixed build system, or (c)
fix the build system yourself and send us the patch. As soon as we have a
working hypre-2.9, we'll include it in petsc-dev (and petsc-3.4, which we
hope to release in a couple months).
On Wed, Jan 9, 2013 at 2:24 AM, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> Hi,
> I _have_ to use hypre-2.9.0b with petsc 3.3.x (because 2.8.0b
> compilation on Windows is broken due to issues with the MSVC 10
> compiler). I am aware of both 2.8.0b being officially used by petsc as
> well as of Jed mentioning building problems in hypre-2.9.0b. I indeed
> can not build 2.9.0b on linux due to errors but - ironically - it is
> the only version I can currently build natively on Windows. Therefore
> I would like to know if the decision to officially use 2.8.0b in petsc
> 3.3.x is dictated exclusively by building infrastructure issues or
> also by some code / API / functionality related issues. Thanks for any
> comments.
> Dominik
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130109/515f1845/attachment.html>
