[petsc-users] More on BlockSize in release 3.3
Matthew Knepley
knepley at gmail.com
Thu Jan 3 09:07:15 CST 2013
On Thu, Jan 3, 2013 at 8:57 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jan 3, 2013 at 6:50 AM, Aldo Bonfiglioli <
> aldo.bonfiglioli at unibas.it> wrote:
>> Dear developers,
>> I have modified
>> src/vec/vec/examples/tutorials/ex14f.F
>> to test 4 different combinations of
>> VecSetValues(Blocked) calls on the
>> local/global representation of the ghosted vector.
>> The runtime option -job now controls the behavior.
>> Things work except when using VecSetValuesBlocked
>> on the LOCAL representation of the ghosted Vector.
>> Is this maybe because the local representation (lx)
>> does not seem to inherit the blocksize from the global vector (gx) it
>> comes from?
>> With 3.3 I cannot any longer set it explicitly using VecSetBlockSize.
>> The modified code is enclosed.
> The problem is that VecDuplicate() does not preserve the local block size.
> Tracking it down.
Pushed a fix to 3.3 which will come out with the next patch release, or
pull it (and its in dev).
Matt
> Matt
>> Regards,
>> Aldo
>> Dr. Aldo Bonfiglioli
>> Associate professor of Fluid Flow Machinery
>> Scuola di Ingegneria
>> Universita' della Basilicata
>> V.le dell'Ateneo lucano, 10 85100 Potenza ITALY
>> tel:+39.0971.205203 fax:+39.0971.205215
>> Publications list <http://publicationslist.org/aldo.bonfiglioli>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130103/f76962bb/attachment.html>
