[petsc-users] An error comes up while updating
Satish Balay
balay at mcs.anl.gov
Tue Jan 1 19:37:28 CST 2013
looks like your mercurial install is broken [and needs a reinstall?]
My system install of mercurial [2.4.1] has 'osutil' at:
asterix:/home/balay>rpm -ql mercurial |grep osutil
/usr/lib64/python2.7/site-packages/mercurial/osutil.so
Satish
On Tue, 1 Jan 2013, Alan wrote:
> Thanks,
> However, here I have another little question on the mercurial:
> Traceback (most recent call last):
> File "/home/zlwei/soft/mercurial/mercurial-1.8.3/hg", line 38, in ?
> mercurial.dispatch.run()
> File "/home/zlwei/soft/mercurial/mercurial-1.8.3/mercurial/dispatch.py",
> line 16, in run
> sys.exit(dispatch(sys.argv[1:]))
> line 21, in dispatch
> u = uimod.ui()
> File "/home/zlwei/soft/mercurial/mercurial-1.8.3/mercurial/ui.py", line 35,
> in __init__
> for f in util.rcpath():
> File "/home/zlwei/soft/mercurial/mercurial-1.8.3/mercurial/util.py", line
> 1346, in rcpath
> _rcpath = os_rcpath()
> 1320, in os_rcpath
> path = system_rcpath()
> File "/home/zlwei/soft/mercurial/mercurial-1.8.3/mercurial/posix.py", line
> 47, in system_rcpath
> path.extend(rcfiles(os.path.dirname(sys.argv[0]) +
> 36, in rcfiles
> rcs.extend([os.path.join(rcdir, f)
> File "/home/zlwei/soft/mercurial/mercurial-1.8.3/mercurial/demandimport.py",
> line 75, in __getattribute__
> self._load()
> line 47, in _load
> mod = _origimport(head, globals, locals)
> ImportError: No module named osutil
> It happens when I'm trying to do 'hg pull -u'. Do you have any idea on
> this.
> thanks,
> Alan
> > fixed now
> > satish
> > On Tue, 1 Jan 2013, Zhenglun (Alan) Wei wrote:
> > > Dear folks,
> > > I had a problem when I was trying to update the PETSc. It says that:
> > > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> > > details):
> > > PETSc makefiles contain mistakes or files are missing on filesystem.
> > > Makefile contains directory not on filesystem: src/snes/utils: ['mesh']
> > > Possible reasons:
> > > 1. Files were deleted locally, try "hg update".
> > > 2. Files were deleted from mercurial, but were not removed from
> > > makefile. Send mail to petsc-maint at mcs.anl.gov.
> > > 3. Someone forgot "hg add" new files. Send mail to
> > > And, here is the configure.log attached.
> > > Thank you so much and Happy New Year !!!
> > > Alan
