[petsc-users] An error comes up while updating
Alan
zhenglun.wei at gmail.com
Tue Jan 1 19:25:24 CST 2013
However, here I have another little question on the mercurial:
Traceback (most recent call last):
File "/home/zlwei/soft/mercurial/mercurial-1.8.3/hg", line 38, in ?
mercurial.dispatch.run()
File
"/home/zlwei/soft/mercurial/mercurial-1.8.3/mercurial/dispatch.py", line
16, in run
sys.exit(dispatch(sys.argv[1:]))
File
21, in dispatch
u = uimod.ui()
File "/home/zlwei/soft/mercurial/mercurial-1.8.3/mercurial/ui.py",
line 35, in __init__
for f in util.rcpath():
File "/home/zlwei/soft/mercurial/mercurial-1.8.3/mercurial/util.py",
line 1346, in rcpath
_rcpath = os_rcpath()
line 1320, in os_rcpath
path = system_rcpath()
File "/home/zlwei/soft/mercurial/mercurial-1.8.3/mercurial/posix.py",
line 47, in system_rcpath
path.extend(rcfiles(os.path.dirname(sys.argv[0]) +
line 36, in rcfiles
rcs.extend([os.path.join(rcdir, f)
File
"/home/zlwei/soft/mercurial/mercurial-1.8.3/mercurial/demandimport.py",
line 75, in __getattribute__
self._load()
File
line 47, in _load
mod = _origimport(head, globals, locals)
ImportError: No module named osutil
It happens when I'm trying to do 'hg pull -u'. Do you have any
idea on this.
thanks,
Alan
> fixed now
> satish
> On Tue, 1 Jan 2013, Zhenglun (Alan) Wei wrote:
>> Dear folks,
>> I had a problem when I was trying to update the PETSc. It says that:
>> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
>> details):
>> PETSc makefiles contain mistakes or files are missing on filesystem.
>> Makefile contains directory not on filesystem: src/snes/utils: ['mesh']
>> Possible reasons:
>> 1. Files were deleted locally, try "hg update".
>> 2. Files were deleted from mercurial, but were not removed from
>> makefile. Send mail to petsc-maint at mcs.anl.gov.
>> 3. Someone forgot "hg add" new files. Send mail to
>> And, here is the configure.log attached.
>> Thank you so much and Happy New Year !!!
>> Alan
