[petsc-users] MATNEST with shell matrices
Matthew Knepley
knepley at gmail.com
Thu Feb 21 16:21:34 CST 2013
On Thu, Feb 21, 2013 at 5:19 PM, Amneet Bhalla <mail2amneet at gmail.com>wrote:
> Can you guys comment on what example case would be best to start off for
> shell
> operators with FieldSplit? The examples I am looking into all start with
> creating native
> PETSc matrices and vectors.
> If possible could you write down steps that would be needed in setting
> such system...
> a) Create matrices using XXXX (?) b) Create vectors using YYYY ....
1) Solve your system with a standard KSP solver, like GMRES
2) Tell PCFIELDSPLIT about your fields using PCFieldSplitSetIS(),
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/PC/PCFieldSplitSetIS.html
Now you are ready.
Matt
> On Thu, Feb 21, 2013 at 3:24 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Thu, Feb 21, 2013 at 4:20 PM, Amneet Bhalla <mail2amneet at gmail.com>wrote:
>>> On Thu, Feb 21, 2013 at 2:57 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>>> that you're happy with and that performs well with fieldsplit or custom
>>>> preconditioning that will be amenable to your MatShells
>>> Is fieldsplit an alternative approach to MatNest and VecNest? The
>>> problem is that I am working on nonnative PETSc
>>> data; so I am not sure which recent methods would support shell
>>> approach. All I want is to use PETSc's algorithm
>>> for solving multicomponent system of equation. I am not bothering about
>>> preconditioning yet, as I will be trying
>>> a custom preconditioner down the road.
>> MatNest is just an optimization matrix format. Get your stuff working
>> with FieldSplit and then think about optimization.
>> Matt
>>> Amneet
>> experiments lead.
>> -- Norbert Wiener
> Amneet
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130221/736d358e/attachment.html>
