[petsc-users] best way to have debug/without-debug builds side by side in petsc-dev
Satish Balay
balay at mcs.anl.gov
Thu Feb 21 13:25:44 CST 2013
Generally its good to tell configure what to do [instead of it
guessing]. In this case that would mean specifying PETSC_ARCH as an
option to configure.
Satish
On Thu, 21 Feb 2013, Geoffrey Irving wrote:
> Yep, that was the problem. Thanks, and apologies for the noise.
> Geoffrey
> On Thu, Feb 21, 2013 at 11:10 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> What's the standard way of having debug and non-debug builds side by
> >> side in an instance of petsc-dev? If I do
> >> ./configure --with-shared-libraries=1
> >> --PETSC_DIR=/Users/irving/otherlab/petsc --download-ml=yes
> >> --with-mpi-dir=/usr/local --with-debugging=0
> >> it defaults to PETSC_ARCH=darwin10.6.0-cxx-debug, which is the same
> >> PETSC_ARCH as for --with-debugging=1. I can manually change
> >> PETSC_ARCH, but it seems odd to have to do this.
> > Perhaps you have PETSC_ARCH set in env. If so - configure picks it up.
> > Satish
> >> Thanks,
> >> Geoffrey
