[petsc-users] best way to have debug/without-debug builds side by side in petsc-dev
Geoffrey Irving irving at naml.us
Thu Feb 21 13:13:33 CST 2013
Yep, that was the problem.  Thanks, and apologies for the noise.
Geoffrey
On Thu, Feb 21, 2013 at 11:10 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Thu, 21 Feb 2013, Geoffrey Irving wrote:
>> What's the standard way of having debug and non-debug builds side by
>> side in an instance of petsc-dev?  If I do
>>     ./configure --with-shared-libraries=1
>> --PETSC_DIR=/Users/irving/otherlab/petsc --download-ml=yes
>> --with-mpi-dir=/usr/local --with-debugging=0
>> it defaults to PETSC_ARCH=darwin10.6.0-cxx-debug, which is the same
>> PETSC_ARCH as for --with-debugging=1.  I can manually change
>> PETSC_ARCH, but it seems odd to have to do this.
> Perhaps you have PETSC_ARCH set in env. If so - configure picks it up.
> Satish
>> Thanks,
>> Geoffrey
