[petsc-users] advice on a linear system solution for a matrix in blocks
Shri abhyshr at mcs.anl.gov
Thu Feb 21 07:35:38 CST 2013
PETSc's solver for block matrices PCFieldsplit http://www.mcs.anl.gov/petsc/petsc-3.3/docs/manualpages/PC/PCFIELDSPLIT.html#PCFIELDSPLIT is what you need. More information on fieldsplit is given in section 4.5 of the manual.
----- Original Message -----
> Dear all,
> I have a linear system in blocks that I would like to solve.
> The system is written as
> [ A C^T ]   b_1
> [ C       B]   b_2
> where C matrix results from a coupling condition in fluid-structure
> interaction and rather sparse depending on the size of the coupling
> surfaces. A and B are also sparse symmetric matrices.
> I was wondering if I could find a solution to this problem without
> factorizing the complete operator matrix but only using, somehow, A
> and
> B and using some algebraic tricks and the sparsity of C.
> Any pointers/ideas are appreciated.
> Best regards,
> Umut
