[petsc-users] EXTERNAL: How to run Petsc in Fortran
Satish Balay
balay at mcs.anl.gov
Mon Apr 29 11:03:29 CDT 2013
On Mon, 29 Apr 2013, Sonya Blade wrote:
> -------------- Build: Debug in Petsc_Fortran (compiler: GNU GFortran Compiler)---------------
> gfortran.exe -Wall -g -Wall -IC:\Users\....\Downloads\petsc-3.3-p6\include\finclude -IC:\Users\...\Downloads\petsc-3.3-p6\arch-mswin-c-debug\include -c D:\....\PROJECTS\CBFortran\Petsc_Fortran\main.f90 -o obj\Debug\main.o
Rename your sourcefile from 'main.f90' to 'main.F90'. gfortran will
preprocess it with the .F90 name.
Are you using makefiles or somthing else to build your application?
We suggest using PETSc makefiles.
Satish
