[petsc-users] EXTERNAL: Re: EXTERNAL: How to run Petsc in Fortran
Wadud.Miah at awe.co.uk Wadud.Miah at awe.co.uk
Mon Apr 29 07:19:21 CDT 2013
Hi Sonya,
As this is Fortran 90, I think you should be using the double colon to allocate variables:
PetscReal :: norm
Wadud.
-----Original Message-----
From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Sonya Blade
Sent: 29 April 2013 13:10
To: petsc-users at mcs.anl.gov
Subject: EXTERNAL: Re: [petsc-users] EXTERNAL: How to run Petsc in Fortran
> What is the compilation command you are executing? It is probably
> because you are not running the pre-processor in Fortran which is
> switched off in the PGI compiler by default.
> Regards,
> Wadud.
What it's got anything to do with PGI compiler I'm using Gnu Fortran?
I try to compile program with the given command lines executions.
-------------- Build: Debug in Petsc_Fortran (compiler: GNU GFortran Compiler)---------------
gfortran.exe -Wall  -g  -Wall   -IC:\Users\....\Downloads\petsc-3.3-p6\include\finclude -IC:\Users\...\Downloads\petsc-3.3-p6\arch-mswin-c-debug\include  -c D:\....\PROJECTS\CBFortran\Petsc_Fortran\main.f90 -o obj\Debug\main.o
>Are you sure that your compiler is preprocessing the file? You usually need
>to name it *.F.
>   Matt
I've tried with every possible fortran file extension, I'm sure that file is being
pre-processed because if I comment the line of "PetscReal norm" it compiles and runs
normally and produces the print statement on console screen.
___________________________________________________
The information in this email and in any attachment(s) is
commercial in confidence. If you are not the named addressee(s)
or
if you receive this email in error then any distribution, copying or
use of this communication or the information in it is strictly
prohibited. Please notify us immediately by email at
admin.internet(at)awe.co.uk, and then delete this message from
your computer. While attachments are virus checked, AWE plc
does not accept any liability in respect of any virus which is not
detected.
AWE Plc
Registered in England and Wales
Registration No 02763902
AWE, Aldermaston, Reading, RG7 4PR
