[petsc-users] IS map for sub mesh
Dharmendar Reddy
dharmareddy84 at gmail.com
Fri Apr 26 17:39:37 CDT 2013
Hello,
I was wondering if you have had time to look into this.
Thanks
Reddy
On Thu, Apr 25, 2013 at 3:57 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Apr 25, 2013 at 4:48 PM, Dharmendar Reddy <dharmareddy84 at gmail.com
> > wrote:
>> On Thu, Apr 25, 2013 at 3:31 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Thu, Apr 25, 2013 at 3:35 PM, Dharmendar Reddy <
>>> dharmareddy84 at gmail.com> wrote:
>>>> Hello,
>>>> I need to access the map from points in subdm to points in dm. Can you
>>>> please provide fortran binding for
>>>> DMPlexCreateSubpointIS(DM dm, IS *subpointIS)
>>>> Pushed to next.
>>>> Also, i was thinking it may be of use to have interface like this..
>>>> DMPlexCreateSubpointIS(DM dm, PetscInt pointDimInSubdm, IS *subpointIS)
>>>> this way i can have map from say (dim)-cells in subdm to corresponding
>>>> (dim)-cells in dm.
>>> The intention here is to use DMPlexGetSubpointMap().
>>> So, i should do the calls below ?
>> DMPlexGetSubpointMap(DM dm, DMLabel subpointMap)
>> DMLabelGetStratumIS(subpointMap,depth,IS)
>> I have had trouble using DMLabel in my fortran code earlier.
>> I can give it a try again, Is there a fortran binding for above functions ?
> Hmm, I have not tested it. I will put it in an example.
> Thanks,
> Matt
>> Thanks
>> Reddy
>>> Matt
>>>> thanks
>>>> Reddy
>>>> Dharmendar Reddy Palle
>>>> Graduate Student
>>>> Microelectronics Research center,
>>>> University of Texas at Austin,
>>>> 10100 Burnet Road, Bldg. 160
>>>> MER 2.608F, TX 78758-4445
>>>> e-mail: dharmareddy84 at gmail.com
>>>> Phone: +1-512-350-9082
>>>> United States of America.
>>>> Homepage: https://webspace.utexas.edu/~dpr342
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> Graduate Student
> experiments lead.
> -- Norbert Wiener
Graduate Student
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130426/8a56e249/attachment.html>
