[petsc-users] Fwd: Any changes in ML usage between 3.1-p8 -> 3.3-p6?
Jozsef Bakosi
jbakosi at lanl.gov
Tue Apr 23 13:57:56 CDT 2013
Hi Mark and Jed,
Thanks for your suggestions. I tried setting the zero pivot and shift as well,
and those do not seem to help. See the attached output.
> On 04.18.2013 10:34, Jed Brown wrote:
> As Mark says, use
> -mg_levels_ksp_type chebyshev -mg_levels_pc_type jacobi
As Mark Christon said earlier, this is not really an option for us because it is
a solution to problem that is different than what we are trying to solve.
The problem is not that we would like to have this particular problem converge,
as BCGS or Hypre handles this problem just fine. What we are trying to track
down is what causes the change in PETSc's behavior going between these two
versions, while keeping the application and ML source code the same, as that
might point out an error on our end, e.g. using an undocumented option, or
relying on a default that has changed, etc. The zeropivot and the shift,
pointing to their diff was a good catch, but it seems like there might be
something else as well that causes a different behavior.
Jozsef
Phase 0 - no. of bdry pts = 0
Aggregation(UC) : Phase 1 - nodes aggregated = 5944 (9124)
Aggregation(UC) : Phase 1 - total aggregates = 293
Aggregation(UC_Phase2_3) : Phase 1 - nodes aggregated = 5944
Aggregation(UC_Phase2_3) : Phase 1 - total aggregates = 293
Aggregation(UC_Phase2_3) : Phase 2a- additional aggregates = 45
Aggregation(UC_Phase2_3) : Phase 2 - total aggregates = 338
Aggregation(UC_Phase2_3) : Phase 2 - boundary nodes = 0
Aggregation(UC_Phase2_3) : Phase 3 - leftovers = 0 and singletons = 0
Gen_Prolongator (level 1) : Max eigenvalue = 1.9726e+00
Prolongator/Restriction smoother (level 1) : damping factor #1 = 6.7594e-01
Prolongator/Restriction smoother (level 1) : ( = 1.3333e+00 / 1.9726e+00)
Smoothed Aggregation : operator complexity = 1.045356e+00.
KSP Object:(PPE_) 4 MPI processes
type: cg
maximum iterations=10000
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
left preconditioning
using nonzero initial guess
using UNPRECONDITIONED norm type for convergence test
PC Object:(PPE_) 4 MPI processes
type: ml
MG: type is MULTIPLICATIVE, levels=3 cycles=v
Cycles per PCApply=1
Using Galerkin computed coarse grid matrices
Coarse grid solver -- level -------------------------------
KSP Object: (PPE_mg_coarse_) 4 MPI processes
type: preonly
maximum iterations=1, initial guess is zero
using NONE norm type for convergence test
PC Object: (PPE_mg_coarse_) 4 MPI processes
type: redundant
Redundant preconditioner: First (color=0) of 4 PCs follows
KSP Object: (PPE_mg_coarse_redundant_) 1 MPI processes
type: preonly
maximum iterations=10000, initial guess is zero
PC Object: (PPE_mg_coarse_redundant_) 1 MPI processes
type: lu
LU: out-of-place factorization
tolerance for zero pivot 1e-12
matrix ordering: nd
factor fill ratio given 5, needed 3.80946
Factored matrix follows:
Matrix Object: 1 MPI processes
type: seqaij
rows=338, cols=338
package used to perform factorization: petsc
total: nonzeros=49302, allocated nonzeros=49302
total number of mallocs used during MatSetValues calls =0
not using I-node routines
linear system matrix = precond matrix:
type: seqaij
rows=338, cols=338
total: nonzeros=12942, allocated nonzeros=26026
Matrix Object: 4 MPI processes
type: mpiaij
rows=338, cols=338
total: nonzeros=12942, allocated nonzeros=12942
not using I-node (on process 0) routines
Down solver (pre-smoother) on level 1 -------------------------------
KSP Object: (PPE_mg_levels_1_) 4 MPI processes
type: richardson
Richardson: damping factor=0.9
PC Object: (PPE_mg_levels_1_) 4 MPI processes
type: bjacobi
block Jacobi: number of blocks = 4
Local solve is same for all blocks, in the following KSP and PC objects:
KSP Object: (PPE_mg_levels_1_sub_) 1 MPI processes
type: preonly
PC Object: (PPE_mg_levels_1_sub_) 1 MPI processes
type: icc
0 levels of fill
using Manteuffel shift
matrix ordering: natural
type: seqaij
rows=2265, cols=2265
total: nonzeros=60131, allocated nonzeros=60131
type: mpiaij
rows=9124, cols=9124
total: nonzeros=267508, allocated nonzeros=267508
Up solver (post-smoother) on level 1 -------------------------------
type: richardson
type: bjacobi
type: preonly
type: icc
0 levels of fill
type: seqaij
type: mpiaij
Down solver (pre-smoother) on level 2 -------------------------------
KSP Object: (PPE_mg_levels_2_) 4 MPI processes
type: richardson
PC Object: (PPE_mg_levels_2_) 4 MPI processes
type: bjacobi
KSP Object: (PPE_mg_levels_2_sub_) 1 MPI processes
type: preonly
PC Object: (PPE_mg_levels_2_sub_) 1 MPI processes
type: icc
0 levels of fill
type: seqaij
rows=59045, cols=59045
total: nonzeros=1504413, allocated nonzeros=1594215
type: mpiaij
rows=236600, cols=236600
total: nonzeros=6183334, allocated nonzeros=12776400
Up solver (post-smoother) on level 2 -------------------------------
type: richardson
type: bjacobi
type: preonly
type: icc
0 levels of fill
type: seqaij
type: mpiaij
type: mpiaij
solver: ||b|| = 5.9221e-03
solver: ||x(0)|| = 0.0000e+00
solver: Iteration: 1 ||r|| = 2.2899e-03 ||x(i+1)-x(i)|| = 5.0933e+00 ||x(i+1)|| = 5.0933e+00
solver: Iteration: 2 ||r|| = 1.3937e-03 ||x(i+1)-x(i)|| = 5.6534e+00 ||x(i+1)|| = 1.0532e+01
solver: Iteration: 3 ||r|| = 8.6624e-04 ||x(i+1)-x(i)|| = 2.6100e+00 ||x(i+1)|| = 1.2788e+01
solver: Iteration: 4 ||r|| = 5.8704e-04 ||x(i+1)-x(i)|| = 9.9167e-01 ||x(i+1)|| = 1.3473e+01
solver: Iteration: 5 ||r|| = 5.7145e-04 ||x(i+1)-x(i)|| = 3.3801e-01 ||x(i+1)|| = 1.3619e+01
solver: Iteration: 6 ||r|| = 1.0164e-03 ||x(i+1)-x(i)|| = 1.1916e-01 ||x(i+1)|| = 1.3629e+01
solver: Iteration: 7 ||r|| = 1.1305e-03 ||x(i+1)-x(i)|| = 5.4793e-03 ||x(i+1)|| = 1.3628e+01
#PETSc Option Table entries:
-Mom_ksp_gmres_classicalgramschmidt
-Mom_pc_asm_overlap 1
-Mom_pc_type asm
-Mom_sub_pc_factor_levels 0
-Mom_sub_pc_type ilu
-PPE_mg_coarse_redundant_pc_factor_zeropivot 1e-12
-PPE_mg_levels_ksp_norm_type none
-PPE_mg_levels_ksp_richardson_scale 0.90
-PPE_mg_levels_ksp_type richardson
-PPE_mg_levels_pc_type bjacobi
-PPE_mg_levels_sub_ksp_norm_type none
-PPE_mg_levels_sub_ksp_type preonly
-PPE_mg_levels_sub_pc_factor_shift_amount 1e-12
-PPE_mg_levels_sub_pc_factor_zeropivot 1e-12
-PPE_mg_levels_sub_pc_type icc
-PPE_pc_mg_cycle_type V
-PPE_pc_mg_smoothdown 1
-PPE_pc_mg_smoothup 1
-PPE_pc_ml_PrintLevel 10
-PPE_pc_ml_maxCoarseSize 1000
-PPE_pc_ml_maxNlevels 10
-c ldc3d_iles.cntl
-i ldc3d.exo
-options_left
-options_table
#End of PETSc Option Table entries
There are 2 unused database options. They are:
Option left: name:-c value: ldc3d_iles.cntl
Option left: name:-i value: ldc3d.exo
