[petsc-users] Advice Being Sought
David Scott
d.scott at ed.ac.uk
Mon Apr 22 11:26:04 CDT 2013
Thanks for the suggestion.
I had tried '-pc_type gamg -pc_gamg_agg_nsmooths 1' with an earlier
version of the code without success. I have tried it again but I get
NaN's after only 90 time steps whereas with block Jacobi it runs quite
happily for 36,000 time steps and produces physically sensible results.
David
On 22/04/2013 13:12, Matthew Knepley wrote:
> On Mon, Apr 22, 2013 at 7:56 AM, David Scott <d.scott at ed.ac.uk
> <mailto:d.scott at ed.ac.uk>> wrote:
> Hello,
> I am working on a fluid-mechanical code to solve the two-phase
> Navier–Stokes equations with levelset interface capturing. I have
> been asked to replace the pressure calculation which uses the SOR
> and Jacobi iterative schemes with a Krylov subspace method. I have
> done this and the code is working but as I have never used PETSc
> before I would like to know if improvements to my code, or the run
> time parameters that I am using, could be made.
> I am using GMRES with a Block Jacobi pre-conditioner. I have tried
> Conjugate Gradient with a Block Jacobi pre-conditioner but it
> diverges. If I use GMRES for the first few thousand time steps and
> then swap to CG it does converge but the speed of execution is
> somewhat reduced.
> Krylov methods do not work with preconditioners. You have a Poisson
> problem, so as abundantly documented in the literature, you should use
> multigrid. The easiest thing to try is
> Thanks,
> Matt
> I have attached relevant excerpts from the code.
> Yours sincerely,
> David Scott
> Dr. D. M. Scott
> Applications Consultant
> Edinburgh Parallel Computing Centre
> Tel. 0131 650 5921
> The University of Edinburgh is a charitable body, registered in
> Scotland, with registration number SC005336.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Dr. D. M. Scott
Tel. 0131 650 5921
