[petsc-users] [Fortran] VTK viewer error
Jed Brown
jedbrown at mcs.anl.gov
Fri Apr 19 00:54:18 CDT 2013
Dharmendar Reddy <dharmareddy84 at gmail.com> writes:
> Now the data in vtu file is calle
> myfieldPoint0 So the pattern is ..<fieldName><Point| Cell><field Id> ?
> where the field Name is the one set using PetscObjectSetName ?
> But why is it not using the name set using PetscSectionSetFieldName ?
The DMDA code (that I wrote before the DMPlex stuff) used field
information, but for whatever reason, I didn't have it available when
writing the DMPlex VTU code. Maybe it was just that the "field"
interface is more complicated in DMPlex.
> If i have a few fields per point then i can manage with the field Ids but
> usually the aux data i look at has about 10 to 12 fields. It would make
> things easier if i can refer to them using Names in the paraview. As the
> viewer is accessing the DM object, why not get the user set field names in
> the default section ?
This is now in 'next'. I've only tested it for a cell-centered problem.
Let me know if it works for you.
commit 1cfafdd3620b0d8e55f5b21e1f3de1941197d333
Author: Jed Brown <jed at 59A2.org>
Date: Fri Apr 19 00:40:19 2013 -0500
DMPlex: teach VTU output about field names and components
Schema is "${ObjectName}${FieldName}.${Component}". For example
SolutionDensity.0
SolutionMomentum.0
SolutionMomentum.1
SolutionMomentum.2
SolutionEnergy.0
src/dm/impls/plex/plexvtu.c | 43 ++++++++++++++++++++++++-----------
1 file changed, 30 insertions(+), 13 deletions(-)
