[petsc-users] Mailing list reply-to munging (was Any changes in ML usage between 3.1-p8 -> 3.3-p6?)
Thu Apr 18 14:06:42 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
> Sure - there is cost for 'minority users. But to save that - you
> propose a cost to majority users [i.e everyone should conciously use
> 'reply-all']
That has always been standard mailing list etiquette.
>> Does the list configuration have an API?  If so, we could have a bot
>> monitoring petsc-users email and subscribing (without delivery)
>> addresses that are Cc'd in approved messages?
> you can check that.
Hmm, I couldn't find it.
> Not sure if its possible to scrub just the attachments. If thats
> possible you can now configure mailman to do that.
It looks like we can do it, but not from the web interface:
http://wiki.list.org/pages/viewpage.action?pageId=7602227
One option would be to apply a good compression like lzma/xz to
configure.log attachments.  That brings a 5MB log file down to 160 kB.
PETSc could compress configure.log up-front, but then you have to use
xzless to look at it and not many people know to do that.
>> > I don't know if there is an option for that. Currently all moderators
>> > get such emails.
>> There is a difference between list "moderator" and "admin", right?  Can
>> the current petsc-maint group be labeled as "moderator" so that we get
>> the attachments?
> Sure - you can set that up now.
Okay, I set up two topics:
* installation
* methods
The former currently matches 'configure.log|make.log' and the latter
matches the following which should be almost all generally "interesting"
threads.
method
|converge
|diverge
|solver
|solving
|performance
|usage
|poisson
|stokes
|elasticity
|compressible
|flow
|preconditioner
|krylov
|domain
Let's see how well this classifies.  If it is accurate, we can mention
that people are welcome to unsubscribe from [installation], and possibly
change the defaults.
