[petsc-users] snes test fails
Dharmendar Reddy
dharmareddy84 at gmail.com
Wed Apr 17 17:30:22 CDT 2013
Hello,
I am solving a one dimensional (linear) Poisson equation. I have
setup a snes problem using DM object. I am using Dirichlet boundary
conditons at both ends of the one dimensional domain. For the test case i
use the same value for potential at both ends.
I am using DMplex object for the mesh and dof lay out.
If i run the solver, i get a constant potential profile as expected.
However, If i run the solver with snes_type test
It is giving an error. what could i have done wrong ?
Testing hand-coded Jacobian, if the ratio is
O(1.e-8), the hand-coded Jacobian is probably correct.
Run with -snes_test_display to show difference
of hand-coded and finite difference Jacobian.
Norm of matrix ratio 1.0913e-10 difference 5.85042e-10 (user-defined state)
Norm of matrix ratio 0.5 difference 5.36098 (constant state -1.0)
Norm of matrix ratio 0.666667 difference 10.722 (constant state 1.0)
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Object is in wrong state!
[0]PETSC ERROR: SNESTest aborts after Jacobian test!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development GIT revision:
e0030536e6573667cee5340eb367e8213e67d68
9 GIT Date: 2013-04-16 21:48:15 -0500
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./PoisTest on a mpi_rScalar_Debug named
login2.stampede.tacc.utexas.edu
by Reddy135 Wed Apr 17 17:22:02 2013
[0]PETSC ERROR: Libraries linked from
/home1/00924/Reddy135/LocalApps/petsc/mpi_rScalar
_Debug/lib
[0]PETSC ERROR: Configure run at Tue Apr 16 22:30:58 2013
[0]PETSC ERROR: Configure options --download-blacs=1 --download-ctetgen=1
--download-
metis=1 --download-mumps=1 --download-parmetis=1 --download-scalapack=1
--download-supe
rlu_dist=1 --download-triangle=1 --download-umfpack=1
--with-blas-lapack-dir=/opt/apps/
intel/13/composer_xe_2013.2.146/mkl/lib/intel64/ --with-debugging=1
--with-mpi-dir=/opt
/apps/intel13/mvapich2/1.9/ --with-petsc-arch=mpi_rScalar_Debug
--with-petsc-dir=/home1
/00924/Reddy135/LocalApps/petsc PETSC_ARCH=mpi_rScalar_Debug
[0]PETSC ERROR:
[0]PETSC ERROR: SNESSolve_Test() line 127 in
/home1/00924/Reddy135/LocalApps/petsc/src/
snes/impls/test/snestest.c
[0]PETSC ERROR: SNESSolve() line 3755 in
/home1/00924/Reddy135/LocalApps/petsc/src/snes
/interface/snes.c
SNESDivergedReason 0
Exiting solve
Dharmendar Reddy Palle
Graduate Student
Microelectronics Research center,
University of Texas at Austin,
10100 Burnet Road, Bldg. 160
MER 2.608F, TX 78758-4445
e-mail: dharmareddy84 at gmail.com
Phone: +1-512-350-9082
United States of America.
Homepage: https://webspace.utexas.edu/~dpr342
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130417/fc1bcb80/attachment.html>
