[petsc-users] MatDenseGetArray question
Jed Brown
jedbrown at mcs.anl.gov
Wed Apr 17 14:32:21 CDT 2013
Michael Povolotskyi <mpovolot at purdue.edu> writes:
> Thank you, one more detail about MatDenseGetArray
> is this statement correct:
> if a dense matrix is serial, the data is stored in memory in a
> column-wise order,
Yes.
> but if a dense matrix is distributed the data is stored in a row-wise
> order?
No, it's still column-major storage, but each process only owns a range
of rows. So the distributed memory partition is by row.
If you have large dense matrices, then chances are that you should
switch from MATDENSE to MATELEMENTAL anyway.
