[petsc-users] Crash when using valgrind
Wed Apr 17 08:43:13 CDT 2013
Can you get a stack trace? Does this happen on a different machine?
Should we turn off signal handling when running in valgrind?
On Apr 17, 2013 6:42 AM, "Dominik Szczerba" <dominik at itis.ethz.ch> wrote:
> I have been successfully using valgrind for a long long time with petsc
> but now suddenly it refuses to work. E.g. calling up a properly functioning
> program causes a crash:
> mpiexec -n 2 valgrind --tool=memcheck -q --num-callers=20 MySolver
> cr_libinit.c:183 cri_init: sigaction() failed: Invalid argument
> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> =   EXIT CODE: 134
> =   CLEANING UP REMAINING PROCESSES
> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> APPLICATION TERMINATED WITH THE EXIT STRING: Aborted (signal 6)
> Same problem if I run without mpiexec at all, just on one proc.
> Google found just one and only related page on valgrind pages but I was
> not able to conclude much. Did anyone else experience the same problem?
> Thanks,
> Dominik
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130417/5aeeadd9/attachment.html>
