[petsc-users] KSPsolver
Tabrez Ali stali at geology.wisc.edu
Tue Apr 16 13:43:38 CDT 2013
Shuangshuang
If you do want to keep multiple versions of MPI/Compilers/Libs etc.
then use the environment modules package. It is a simple one time
install that will make your life easy.
http://modules.sourceforge.net/
T
On Apr 16, 2013, at 1:29 PM, Jed Brown wrote:
> "Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov> writes:
>> Hello, everyone, I'm trying to run the following example:
>> http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex12.c.html
>> It is said that this example solves a linear system in parallel with
>> KSP.
>> However, when I ran it on my clusters, I always got the same copy
>> running multiple times. I printed the Istart and Iend numbers right
>> after the MatGetOwnershipRange, and noticed that the index on each
>> processor are all the same, which is [0, 56].
> Your mpiexec does not match the MPI library you compiled with.
