[petsc-users] KSPsolver
Hong Zhang
hzhang at mcs.anl.gov
Tue Apr 16 13:25:56 CDT 2013
What do you get by running
mpiexec -n 2 ./ex12 -ksp_view
I get
KSP Object: 2 MPI processes
type: gmres
GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
GMRES: happy breakdown tolerance 1e-30
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
left preconditioning
using PRECONDITIONED norm type for convergence test
PC Object: 2 MPI processes
type: ourjacobi
linear system matrix = precond matrix:
Matrix Object: 2 MPI processes
type: mpiaij
rows=56, cols=56
total: nonzeros=250, allocated nonzeros=560
total number of mallocs used during MatSetValues calls =0
not using I-node (on process 0) routines
Norm of error 2.10144e-06 iterations 14
Hong
On Tue, Apr 16, 2013 at 1:17 PM, Jin, Shuangshuang <
Shuangshuang.Jin at pnnl.gov> wrote:
> Hello, everyone, I’m trying to run the following example: *
> http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex12.c.html
> *<http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex12.c.html>
> It is said that this example solves a linear system in parallel with KSP.
> However, when I ran it on my clusters, I always got the same copy running
> multiple times. I printed the Istart and Iend numbers right after the
> MatGetOwnershipRange, and noticed that the index on each processor are all
> the same, which is [0, 56].
> The following is the printout from the runs:
> [d3m956 at olympus ksp]$ mpiexec -n 1 ./ex12
> 0, 56
> [d3m956 at olympus ksp]$ mpiexec -n 2 ./ex12
> 0, 56
> 0, 56
> [d3m956 at olympus ksp]$ mpiexec -n 4 ./ex12
> 0, 56
> 0, 56
> 0, 56
> 0, 56
> Can anyone explain to me why I ran into this issue? Anything I missed?
> Thanks,
> Shuangshuang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130416/2dfee303/attachment.html>
