[petsc-users] KSPCG solution blow up
Mark F. Adams
mark.adams at columbia.edu
Mon Apr 15 17:07:41 CDT 2013
You need to use AIJ for gamg.
ML might work. You need to configure with ML. It is an external package.
On Apr 15, 2013, at 5:40 PM, Hugo Gagnon <opensource.petsc at user.fastmail.fm> wrote:
> Good point, this is indeed linear elasticity. Following your suggestion I first got the following error since I now use MATBAIJ:
> [0]PCSetData_AGG bs=3 MM=30441
> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
> [0]PETSC ERROR: Arguments are incompatible!
> [0]PETSC ERROR: MatMatMult requires A, mpibaij, to be compatible with B, mpiaij!
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 6, Mon Feb 11 12:26:34 CST 2013
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: /Users/hugo/Documents/jetstream/jetstream_x86_64 on a arch-darw named user204-27.wireless.utoronto.ca by hugo Mon Apr 15 17:31:55 2013
> [0]PETSC ERROR: Libraries linked from /Users/hugo/Documents/petsc-3.3-p6/arch-darwin-c-opt/lib
> [0]PETSC ERROR: Configure run at Mon Feb 18 15:08:07 2013
> [0]PETSC ERROR: Configure options --with-debugging=0
> [0]PETSC ERROR: MatMatMult() line 8617 in src/mat/interface/matrix.c
> [0]PETSC ERROR: PCGAMGOptprol_AGG() line 1358 in src/ksp/pc/impls/gamg/agg.c
> [0]PETSC ERROR: PCSetUp_GAMG() line 673 in src/ksp/pc/impls/gamg/gamg.c
> [0]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: PCApply() line 380 in src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: KSPSolve_CG() line 139 in src/ksp/ksp/impls/cg/cg.c
> [0]PETSC ERROR: KSPSolve() line 446 in src/ksp/ksp/interface/itfunc.c
> I tried converting the matrix to MATAIJ with:
> call MatConvert(Paa,MATAIJ,MAT_INITIAL_MATRIX,Paa2,Pierr)
> and now I have this error (with ksp_view):
> [0]PCSetData_AGG bs=1 MM=30441
> KSPCG resid. tolerance target = 1.000E-10
> KSPCG initial residual |res0| = 8.981E-02
> KSPCG iter = 0: |res|/|res0| = 1.000E+00
> KSPCG iter = 1: |res|/|res0| = 4.949E-01
> KSP Object: 2 MPI processes
> type: cg
> maximum iterations=4000
> tolerances: relative=1e-10, absolute=1e-50, divergence=10000
> left preconditioning
> using nonzero initial guess
> using PRECONDITIONED norm type for convergence test
> PC Object: 2 MPI processes
> type: gamg
> MG: type is MULTIPLICATIVE, levels=2 cycles=v
> Cycles per PCApply=1
> Using Galerkin computed coarse grid matrices
> Coarse grid solver -- level -------------------------------
> KSP Object: (mg_coarse_) 2 MPI processes
> type: gmres
> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
> GMRES: happy breakdown tolerance 1e-30
> maximum iterations=1, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
> using NONE norm type for convergence test
> PC Object: (mg_coarse_) 2 MPI processes
> type: bjacobi
> block Jacobi: number of blocks = 2
> Local solve info for each block is in the following KSP and PC objects:
> [0] number of local blocks = 1, first local block number = 0
> [0] local block number 0
> KSP Object: (mg_coarse_sub_) 1 MPI processes
> type: preonly
> KSP Object: (mg_coarse_sub_) maximum iterations=10000, initial guess is zero
> 1 MPI processes
> type: preonly
> PC Object: (mg_coarse_sub_) 1 MPI processes
> PC Object: (mg_coarse_sub_) type: lu
> LU: out-of-place factorization
> 1 MPI processes
> type: lu
> tolerance for zero pivot 2.22045e-14
> matrix ordering: nd
> factor fill ratio given 5, needed 5.06305
> Factored matrix follows:
> matrix ordering: nd
> factor fill ratio given 5, needed 0
> Matrix Object: Factored matrix follows:
> 1 MPI processes
> type: seqaij
> Matrix Object: 1 MPI processes
> rows=552, cols=552
> type: seqaij
> package used to perform factorization: petsc
> rows=0, cols=0
> total: nonzeros=106962, allocated nonzeros=106962
> total number of mallocs used during MatSetValues calls =0
> not using I-node routines
> linear system matrix = precond matrix:
> total: nonzeros=1, allocated nonzeros=1
> type: seqaij
> Matrix Object: rows=552, cols=552
> 1 MPI processes
> type: seqaij
> total: nonzeros=21126, allocated nonzeros=21126
> rows=0, cols=0
> total: nonzeros=0, allocated nonzeros=0
> [1] number of local blocks = 1, first local block number = 1
> [1] local block number 0
> Matrix Object: 2 MPI processes
> type: mpiaij
> rows=552, cols=552
> not using I-node (on process 0) routines
> Down solver (pre-smoother) on level 1 -------------------------------
> KSP Object: (mg_levels_1_) 2 MPI processes
> type: chebyshev
> Chebyshev: eigenvalue estimates: min = 0.0508405, max = 5.88746
> maximum iterations=2
> PC Object: (mg_levels_1_) 2 MPI processes
> type: jacobi
> type: mpiaij
> rows=60879, cols=60879
> total: nonzeros=4509729, allocated nonzeros=4509729
> using I-node (on process 0) routines: found 10147 nodes, limit used is 5
> Up solver (post-smoother) same as down solver (pre-smoother)
> type: mpiaij
> Error in FEMesh_Mod::moveFEMeshPETSc() : KSP returned with error code = -8
> Hugo Gagnon
> On 2013-04-15, at 5:26 PM, Mark F. Adams <mark.adams at columbia.edu> wrote:
>> Its probably not worth trying to verify the code with ILU(3) because the space of algorithms is large as Jed points out (e.g., ILU(3) does not fully define the solver unless they use the same node ordering, shifting strategies and whatever else your ILU is doing to make ILU not suck). It looks like you are doing 3D elasticity. Try
>> -pc_type gamg
>> -pc_gamg_agg_nsmooths 1
>> assuming you have v3.3 or higher.
>> On Apr 15, 2013, at 5:15 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> Hugo Gagnon <opensource.petsc at user.fastmail.fm> writes:
>>>> For the problem I'm describing my serial in-house solver does not work
>>>> with ILU(0) but works with ILU(3). I have no option to run Jacobi.
>>>> When I apply the same problem to PETSc's PC solver with ILU(3) in
>>>> serial I get KSP_DIVERGED_INDEFINITE_PC
>>> Does your in-house ILU(3) use a different ordering? What shift scheme
>>> does it use?
>>>> on the first iteration (in MPI the solution somewhat converges but
>>>> very slowly).
>>>> call KSPGetPC(Pksp,Ppc,Pierr)
>>>> call PCSetType(Ppc,PCILU,Pierr)
>>>> call PCFactorSetLevels(Ppc,3,Pierr)
>>>> This effectively changes the fill level from 0 to 3, right?
>>> This only works in serial. Check the -ksp_view output to see what is
>>> done. You should just call KSPSetFromOptions() and use run-time options
>>> to configure the solver. You can do it from code later, but writing
>>> code is slow to figure out what works.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130415/a0703c28/attachment-0001.html>
