[petsc-users] KSPCG solution blow up
Hugo Gagnon opensource.petsc at user.fastmail.fm
Mon Apr 15 16:40:46 CDT 2013
Good point, this is indeed linear elasticity.  Following your suggestion I first got the following error since I now use MATBAIJ:
[0]PCSetData_AGG bs=3 MM=30441
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Arguments are incompatible!
[0]PETSC ERROR: MatMatMult requires A, mpibaij, to be compatible with B, mpiaij!
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 6, Mon Feb 11 12:26:34 CST 2013
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: /Users/hugo/Documents/jetstream/jetstream_x86_64 on a arch-darw named user204-27.wireless.utoronto.ca by hugo Mon Apr 15 17:31:55 2013
[0]PETSC ERROR: Libraries linked from /Users/hugo/Documents/petsc-3.3-p6/arch-darwin-c-opt/lib
[0]PETSC ERROR: Configure run at Mon Feb 18 15:08:07 2013
[0]PETSC ERROR: Configure options --with-debugging=0
[0]PETSC ERROR: MatMatMult() line 8617 in src/mat/interface/matrix.c
[0]PETSC ERROR: PCGAMGOptprol_AGG() line 1358 in src/ksp/pc/impls/gamg/agg.c
[0]PETSC ERROR: PCSetUp_GAMG() line 673 in src/ksp/pc/impls/gamg/gamg.c
[0]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[0]PETSC ERROR: PCApply() line 380 in src/ksp/pc/interface/precon.c
[0]PETSC ERROR: KSPSolve_CG() line 139 in src/ksp/ksp/impls/cg/cg.c
[0]PETSC ERROR: KSPSolve() line 446 in src/ksp/ksp/interface/itfunc.c
I tried converting the matrix to MATAIJ with:
call MatConvert(Paa,MATAIJ,MAT_INITIAL_MATRIX,Paa2,Pierr)
and now I have this error (with ksp_view):
[0]PCSetData_AGG bs=1 MM=30441
   KSPCG resid. tolerance target  =   1.000E-10
   KSPCG initial residual |res0|  =   8.981E-02
   KSPCG iter =    0: |res|/|res0| =  1.000E+00
   KSPCG iter =    1: |res|/|res0| =  4.949E-01
KSP Object: 2 MPI processes
  type: cg
  maximum iterations=4000
  tolerances:  relative=1e-10, absolute=1e-50, divergence=10000
  left preconditioning
  using nonzero initial guess
  using PRECONDITIONED norm type for convergence test
PC Object: 2 MPI processes
  type: gamg
    MG: type is MULTIPLICATIVE, levels=2 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object:    (mg_coarse_)     2 MPI processes
      type: gmres
        GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
        GMRES: happy breakdown tolerance 1e-30
      maximum iterations=1, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
      using NONE norm type for convergence test
    PC Object:    (mg_coarse_)     2 MPI processes
      type: bjacobi
        block Jacobi: number of blocks = 2
        Local solve info for each block is in the following KSP and PC objects:
      [0] number of local blocks = 1, first local block number = 0
        [0] local block number 0
        KSP Object:        (mg_coarse_sub_)         1 MPI processes
          type: preonly
              KSP Object:        (mg_coarse_sub_)        maximum iterations=10000, initial guess is zero
     1 MPI processes
          type: preonly
        PC Object:        (mg_coarse_sub_)         1 MPI processes
        PC Object:        (mg_coarse_sub_)            type: lu
            LU: out-of-place factorization
       1 MPI processes
          type: lu
            tolerance for zero pivot 2.22045e-14
            matrix ordering: nd
            factor fill ratio given 5, needed 5.06305
                      Factored matrix follows:
                matrix ordering: nd
            factor fill ratio given 5, needed 0
          Matrix Object:                        Factored matrix follows:
                 1 MPI processes
                  type: seqaij
Matrix Object:                 1 MPI processes
                    rows=552, cols=552
                type: seqaij
                          package used to perform factorization: petsc
              rows=0, cols=0
                        total: nonzeros=106962, allocated nonzeros=106962
                          total number of mallocs used during MatSetValues calls =0
                    not using I-node routines
          linear system matrix = precond matrix:
        total: nonzeros=1, allocated nonzeros=1
                  type: seqaij
        Matrix Object:                rows=552, cols=552
       1 MPI processes
            type: seqaij
        total: nonzeros=21126, allocated nonzeros=21126
                  rows=0, cols=0
                  total: nonzeros=0, allocated nonzeros=0
      [1] number of local blocks = 1, first local block number = 1
        [1] local block number 0
      Matrix Object:       2 MPI processes
        type: mpiaij
        rows=552, cols=552
          not using I-node (on process 0) routines
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object:    (mg_levels_1_)     2 MPI processes
      type: chebyshev
        Chebyshev: eigenvalue estimates:  min = 0.0508405, max = 5.88746
      maximum iterations=2
    PC Object:    (mg_levels_1_)     2 MPI processes
      type: jacobi
        type: mpiaij
        rows=60879, cols=60879
        total: nonzeros=4509729, allocated nonzeros=4509729
          using I-node (on process 0) routines: found 10147 nodes, limit used is 5
  Up solver (post-smoother) same as down solver (pre-smoother)
    type: mpiaij
 Error in FEMesh_Mod::moveFEMeshPETSc() : KSP returned with error code =           -8
  Hugo Gagnon
On 2013-04-15, at 5:26 PM, Mark F. Adams <mark.adams at columbia.edu> wrote:
> Its probably not worth trying to verify the code with ILU(3) because the space of algorithms is large as Jed points out (e.g., ILU(3) does not fully define the solver unless they use the same node ordering, shifting strategies and whatever else your ILU is doing to make ILU not suck).  It looks like you are doing 3D elasticity. Try
> -pc_type gamg
> -pc_gamg_agg_nsmooths 1
> assuming you have v3.3 or higher.
> On Apr 15, 2013, at 5:15 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> Hugo Gagnon <opensource.petsc at user.fastmail.fm> writes:
>>> For the problem I'm describing my serial in-house solver does not work
>>> with ILU(0) but works with ILU(3).  I have no option to run Jacobi.
>>> When I apply the same problem to PETSc's PC solver with ILU(3) in
>>> serial I get KSP_DIVERGED_INDEFINITE_PC
>> Does your in-house ILU(3) use a different ordering?  What shift scheme
>> does it use?
>>> on the first iteration (in MPI the solution somewhat converges but
>>> very slowly).
>>> call KSPGetPC(Pksp,Ppc,Pierr)
>>> call PCSetType(Ppc,PCILU,Pierr)
>>> call PCFactorSetLevels(Ppc,3,Pierr)
>>> This effectively changes the fill level from 0 to 3, right?
>> This only works in serial.  Check the -ksp_view output to see what is
>> done.  You should just call KSPSetFromOptions() and use run-time options
>> to configure the solver.  You can do it from code later, but writing
>> code is slow to figure out what works.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130415/ba1624ea/attachment.html>
