[petsc-users] algorithm to get pure real eigen valule for general eigenvalue problem(Non-hermitian type)
Jose E. Roman
jroman at dsic.upv.es
Mon Apr 15 10:34:37 CDT 2013
El 15/04/2013, a las 17:25, Zhang Wei escribió:
> Hi, thanks for your reply!
> Here is my code:
> // Compute the operator matrix that defines the eigensystem, Ax=kx
> ierr = MatCreateShell(PETSC_COMM_WORLD,n,n,PETSC_DETERMINE,PETSC_DETERMINE,NULL,&A);CHKERRQ(ierr);
> ierr = MatSetFromOptions(A);CHKERRQ(ierr);
> ierr = MatShellSetContext(A, &pa); CHKERRQ(ierr);
> ierr = MatShellSetOperation(A, MATOP_MULT, (void(*)()) MatVecMult); CHKERRQ(ierr);
> ierr = MatGetVecs(A, PETSC_NULL,&xr); CHKERRQ(ierr);
> ierr = MatGetVecs(A, PETSC_NULL,&xi); CHKERRQ(ierr);
> ierr = MatGetVecs(A, PETSC_NULL,&iv); CHKERRQ(ierr);
> // Create the eigensolver and set various options
> ierr = EPSCreate(PETSC_COMM_WORLD,&eps);CHKERRQ(ierr);
> // Set operators. In this case, it is a standard eigenvalue problem
> ierr = EPSSetOperators(eps, A, PETSC_NULL);CHKERRQ(ierr);
> ierr = EPSSetProblemType(eps, EPS_NHEP);CHKERRQ(ierr);
> ierr = EPSSetDimensions(eps, nev, ncv, mpd);CHKERRQ(ierr);
> ierr = EPSSetWhichEigenpairs(eps,which);CHKERRQ(ierr);
> ierr = EPSSetType(eps,method.c_str());CHKERRQ(ierr);
> ierr = EPSSetTolerances(eps,s_tol,s_maxit);CHKERRQ(ierr);
> ierr = EPSSetConvergenceTest(eps,cov);CHKERRQ(ierr);
> ierr = EPSKrylovSchurSetRestart(eps,keep);CHKERRQ(ierr);
> // Set solver parameters at runtime
> ierr = EPSSetFromOptions(eps); CHKERRQ(ierr);
> // Set initial vector
> ierr = pa.setInitialVector(iv);
> ierr = EPSSetInitialSpace(eps,1,&iv);CHKERRQ(ierr);
> ierr = EPSView(eps, PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
> // Solve the eigensystem
> ierr = EPSSolve(eps);CHKERRQ(ierr);
> and pa is a class, where I define the OP, MatVecMult. It actually looks like this:
> PetscErrorCode MatVecMult(Mat A, Vec x, Vec y)
> linearizedTimeStepper *pa;
> MatShellGetContext(A, &pa);
> return pa->MatVecMult(A, x, y);
This code is basically correct. What I was asking is whether you had tested the matrix (that is, pa->MatVecMult) in other contexts before computing eigenvalues.
Jose
