[petsc-users] algorithm to get pure real eigen valule for general eigenvalue problem(Non-hermitian type)
Zhang Wei
zhang.wei at chalmers.se
Mon Apr 15 10:25:51 CDT 2013
Hi, thanks for your reply!
Here is my code:
// Compute the operator matrix that defines the eigensystem, Ax=kx
ierr = MatCreateShell(PETSC_COMM_WORLD,n,n,PETSC_DETERMINE,PETSC_DETERMINE,NULL,&A);CHKERRQ(ierr);
ierr = MatSetFromOptions(A);CHKERRQ(ierr);
ierr = MatShellSetContext(A, &pa); CHKERRQ(ierr);
ierr = MatShellSetOperation(A, MATOP_MULT, (void(*)()) MatVecMult); CHKERRQ(ierr);
ierr = MatGetVecs(A, PETSC_NULL,&xr); CHKERRQ(ierr);
ierr = MatGetVecs(A, PETSC_NULL,&xi); CHKERRQ(ierr);
ierr = MatGetVecs(A, PETSC_NULL,&iv); CHKERRQ(ierr);
// Create the eigensolver and set various options
ierr = EPSCreate(PETSC_COMM_WORLD,&eps);CHKERRQ(ierr);
// Set operators. In this case, it is a standard eigenvalue problem
ierr = EPSSetOperators(eps, A, PETSC_NULL);CHKERRQ(ierr);
ierr = EPSSetProblemType(eps, EPS_NHEP);CHKERRQ(ierr);
ierr = EPSSetDimensions(eps, nev, ncv, mpd);CHKERRQ(ierr);
ierr = EPSSetWhichEigenpairs(eps,which);CHKERRQ(ierr);
ierr = EPSSetType(eps,method.c_str());CHKERRQ(ierr);
ierr = EPSSetTolerances(eps,s_tol,s_maxit);CHKERRQ(ierr);
ierr = EPSSetConvergenceTest(eps,cov);CHKERRQ(ierr);
ierr = EPSKrylovSchurSetRestart(eps,keep);CHKERRQ(ierr);
// Set solver parameters at runtime
ierr = EPSSetFromOptions(eps); CHKERRQ(ierr);
// Set initial vector
ierr = pa.setInitialVector(iv);
ierr = EPSSetInitialSpace(eps,1,&iv);CHKERRQ(ierr);
ierr = EPSView(eps, PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr);
// Solve the eigensystem
ierr = EPSSolve(eps);CHKERRQ(ierr);
and pa is a class, where I define the OP, MatVecMult. It actually looks like this:
PetscErrorCode MatVecMult(Mat A, Vec x, Vec y)
linearizedTimeStepper *pa;
MatShellGetContext(A, &pa);
return pa->MatVecMult(A, x, y);
-----Original Message-----
From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Jose E. Roman
Sent: den 15 april 2013 17:01
To: PETSc users list
Subject: Re: [petsc-users] algorithm to get pure real eigen valule for general eigenvalue problem(Non-hermitian type)
El 15/04/2013, a las 16:50, Zhang Wei escribió:
> Hi
> Since the case is not that big(size of matrix is 9600x9600. ). I have done test in the first way, which gives me a 2.1 Gb ASCII file. The eigen values I get from matlab are :
>> In eigs>processEUPDinfo at 1340
> In eigs at 357
>>> c
> c =
> 0
> 0
> 0
> 0
> 1.9405 - 0.4733i
> 1.9405 + 0.4733i
> And what I got from slepc are :
> 0 1.99988
> 1 1.99974
> 2 1.99971
> 3 1.99913+0.0370552j
> 4 1.99913+-0.0370552j
> 5 1.99894+0.0370115j
> Non of them is right one. And on the other hand there are lots of small values in the matrix which are almost in order of 1e-7 and even smaller.
> Could it be the reason resulting such problem?
Note that if you are trasferring the matrix via a text file, then the matrix loaded in Matlab will differ slightly form the one being handled by SLEPc, so you can expect differences in eigenvalues. For a more equivalent computation you should transfer the matrix in binary format.
Anyway, my impression is that you have a bug in the code that generates the matrix, so I would suggest checking that. Having small nonzero entries in the matrix should not be a problem for the eigensolver.
Jose
