[petsc-users] FIAT Error
Mon Apr 8 08:55:33 CDT 2013
On Mon, Apr 8, 2013 at 8:44 AM, Dharmendar Reddy <dharmareddy84 at gmail.com>wrote:
> do you mean PetscGenerateFEMQuadrature.py will be moved to C ? using FIAT
> internally ?
Yes.
> What should be the dim and order for P2-P1 on triangle
> i am trying to generate ex62.h
>  58:   This code can be generated using 'bin/pythonscripts/PetscGenerateFEMQuadrature.py dim order dim 1 laplacian dim order 1 1 gradient src/snes/examples/tutorials/ex62.h'
You can always look in builder.py. I run the tests using it.
bin/pythonscripts/PetscGenerateFEMQuadrature.py 2 2 2 1 laplacian 2 1
   Matt
> On Mon, Apr 8, 2013 at 8:35 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Apr 8, 2013 at 8:33 AM, Dharmendar Reddy <dharmareddy84 at gmail.com
>> > wrote:
>>> Hello,
>>>         I am getting a FIAT related error. I am using branch
>>> knepley/pylith. Am i missing something ?
>> You need your Python path pointing to the installation:
>>   export
>> PYTHONPATH=${PYTHONPATH}:${PETSC_DIR}/${PETSC_ARCH}/lib:${PETSC_DIR}/${PETSC_ARCH}/lib/python2.6/site-packages
>> We are planning to move all this functionality to C soon.
>>    Matt
>>> login3$ $PETSC_DIR/bin/pythonscripts/PetscGenerateFEMQuadrature.py dim
>>> order dim 1 lapla
>>> cian dim order 1 1 gradient ex62.h
>>> Traceback (most recent call last):
>>>   File
>>> "/home1/00924/Reddy135/LocalApps/petsc/bin/pythonscripts/PetscGenerateFEMQuadratur
>>> e.py", line 15, in <module>
>>>     from FIAT.reference_element import default_simplex
>>> ImportError: No module named FIAT.reference_element
>>> I have used the following configOpts
>>> configOpts_Opt= --with-debugging=0 \
>>>             --with-petsc-arch=${PETSC_ARCH_Opt} \
>>>             --with-petsc-dir=${PETSC_DIR} \
>>>             --with-mpi-dir=${mpiDir} \
>>>             --with-scalar-type=real \
>>>             --with-blas-lapack-dir=${lapackDIR} \
>>>             --with-clanguage=cxx \
>>>             --download-boost=1 \
>>>             --download-umfpack=1 \
>>>             --download-superlu_dist=1 \
>>>             --download-metis=1 \
>>>             --download-parmetis=1 \
>>>             --download-mumps=1 \
>>>             --download-scalapack=1 \
>>>             --download-blacs=1\
>>>             --download-triangle=1 \
>>>             --download-ctetgen=1 \
>>>             --download-chaco=1 \
>>>             --download-scientificpython \
>>>             --download-fiat \
>>>             --download-generator
>>> Dharmendar Reddy Palle
>>> Graduate Student
>>> Microelectronics Research center,
>>> University of Texas at Austin,
>>> 10100 Burnet Road, Bldg. 160
>>> MER 2.608F, TX 78758-4445
>>> e-mail: dharmareddy84 at gmail.com
>>> Phone: +1-512-350-9082
>>> United States of America.
>>> Homepage: https://webspace.utexas.edu/~dpr342
>> experiments lead.
>> -- Norbert Wiener
> Graduate Student
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130408/23b55a97/attachment.html>
