[petsc-users] FIAT Error
Dharmendar Reddy dharmareddy84 at gmail.com
Mon Apr 8 08:44:53 CDT 2013
do you mean PetscGenerateFEMQuadrature.py will be moved to C ? using FIAT
internally ?
What should be the dim and order for P2-P1 on triangle
i am trying to generate ex62.h
 58:   This code can be generated using
'bin/pythonscripts/PetscGenerateFEMQuadrature.py dim order dim 1
laplacian dim order 1 1 gradient src/snes/examples/tutorials/ex62.h'
On Mon, Apr 8, 2013 at 8:35 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Apr 8, 2013 at 8:33 AM, Dharmendar Reddy <dharmareddy84 at gmail.com>wrote:
>> Hello,
>>         I am getting a FIAT related error. I am using branch
>> knepley/pylith. Am i missing something ?
> You need your Python path pointing to the installation:
>   export
> PYTHONPATH=${PYTHONPATH}:${PETSC_DIR}/${PETSC_ARCH}/lib:${PETSC_DIR}/${PETSC_ARCH}/lib/python2.6/site-packages
> We are planning to move all this functionality to C soon.
>    Matt
>> login3$ $PETSC_DIR/bin/pythonscripts/PetscGenerateFEMQuadrature.py dim
>> order dim 1 lapla
>> cian dim order 1 1 gradient ex62.h
>> Traceback (most recent call last):
>>   File
>> "/home1/00924/Reddy135/LocalApps/petsc/bin/pythonscripts/PetscGenerateFEMQuadratur
>> e.py", line 15, in <module>
>>     from FIAT.reference_element import default_simplex
>> ImportError: No module named FIAT.reference_element
>> I have used the following configOpts
>> configOpts_Opt= --with-debugging=0 \
>>             --with-petsc-arch=${PETSC_ARCH_Opt} \
>>             --with-petsc-dir=${PETSC_DIR} \
>>             --with-mpi-dir=${mpiDir} \
>>             --with-scalar-type=real \
>>             --with-blas-lapack-dir=${lapackDIR} \
>>             --with-clanguage=cxx \
>>             --download-boost=1 \
>>             --download-umfpack=1 \
>>             --download-superlu_dist=1 \
>>             --download-metis=1 \
>>             --download-parmetis=1 \
>>             --download-mumps=1 \
>>             --download-scalapack=1 \
>>             --download-blacs=1\
>>             --download-triangle=1 \
>>             --download-ctetgen=1 \
>>             --download-chaco=1 \
>>             --download-scientificpython \
>>             --download-fiat \
>>             --download-generator
>> Dharmendar Reddy Palle
>> Graduate Student
>> Microelectronics Research center,
>> University of Texas at Austin,
>> 10100 Burnet Road, Bldg. 160
>> MER 2.608F, TX 78758-4445
>> e-mail: dharmareddy84 at gmail.com
>> Phone: +1-512-350-9082
>> United States of America.
>> Homepage: https://webspace.utexas.edu/~dpr342
> experiments lead.
> -- Norbert Wiener
Graduate Student
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130408/753ff85c/attachment.html>
